Where can i buy this auto com from?
ninja
ninja
DK- The Bogs Dollocks!!!
NEVER SAY IT CANT BE DONE!!
The thanks button works wonders!!
DONT SEND ME PM'S ASKING FOR OTHER MEMBERS WORK OR PASSWORDS
Hi ninja123, you buy them online from www.autocom.se
or you can buy a used one from ebay .
There are clones out the to
Hello everyone at DK. it must surely be some way to bypass the control of the serial number of the units, I know nothing about the programming of software, but some kind soul out there might be?
Must be a way without having to program the device on to get everything working?
Cheat program that is a different serial number. or can someone tell me how I change serial, without mass exchange of software and so on.
Thanks in advance Alex
simple..
you need to read the 29f800 flash and ATtiny45 and change it with another one original.
you can not change serial in 29f800 because is encrypted,the way it did it is like that,read old one and put another data on flash and ATtiny from another unit,but ofcourse you need the 12 digits serial from previous unit to activate the soft..
Is been done long time ago here,this is the way it did it and is not been with is knowledge and experiences.
took it from another person....
I have dumps and serials from many units
Chokito5 (27th June, 2013)
My second bad experience with autocom truck:
First cant diag... i have changed the resistors and the two BUS IC and then daig well.
Meanwhile i was testing the repaired autocom, inside one relay switched off ( i heard, and supose that) and then BOOOM.
I have opened the autocom again and i see one capacitor blowed.
See attached picture.
BR!
as far as i have seen clones has bad quality in capacitors. so you must use more voltage capacitors fotr not have problems with all clones .
i have change all pcb in clones that i have bought and knoe there are working perfect withount disapointing to me never
Yes, you are right.
They have a low voltage capacitors. The original Autocom has same capacitance with more voltage ( 35V).
I will change it today.
Anyway, the cheap tool will be more expensive than original....
hello
has anybody test it with obd2 generic
i can read cars on k and can but not these cars with kwp2000
why
Strange things going to happened when you use generic bluetooth connection with your Autocom.
In my case, when I used bluetooth I can not acces AC (climate control unit) unit on Audi A6 AYM2.5 TDI, MY2002, but when I plug Autocom on USB connection, everything going fine, I can connect to climate control unit without any problems.
So please, test it with USB connection, seems that bluetooth works OK only with BELKIN Bluetooth adapters (or adapters with same chipset)
Regards and respect
strange things going to happened
please can you send me the password???
I haven't autocom diagnose but i have bought truck cable's set.
Volvo 12 pin truck cable have power and gnd inverted.
Other cable seem be ok.
Hope this helpfull
