I tried to uninstall, I run the CCleaner, install again, but nothing result.
I delete the FTDI, when I connect the Autocom to my computer that install the drivers again, and WORK perfect!
Thanks your help!!!!
please send me pass
+thanks
I repair several Autocom CDP but all same problems with BT modul.
Low range, and outside antena is FAKE
Look in picture, solder small wire between BT modul antena and conector to outside antena.
Range is biger for BT.
Pin distance between alu box and board
I cut all pin from relay, becouse is too long, <1 mm to make conect to alu box if accidentally squeeze box
Col19 (31st October, 2019)
look this manual of BT modul.
I find on ebay for 8$, and download PDF it is same like in Autocom
check power suply 3,3v and other pin, and solder again,
BT link to external antenna will improve bt range, maybe ...
This not resolve problem with non working BT module.
External antena on this model inside not conect to BT antena, and if conect to external over wire work 100%. I see model where is solder but BT modul is diferent and conector for ext antena is upper
but if you have resolve problem with BT write what is problem with BT?
power 3,3V ?
bad soldering?
New "AUTOCOM CDP Plus for Cars & Trucks & Generic 3 in 1" or old "AUTOCOM CDP Pro Cars & Trucks" = which one to choose?
heeeeeeelp i get nsis error when i try to install autocom 2011-3 on xp...WHY..
did you have istall sp3? no? try to install
