Experience with Autocom - Page 90
Page 90 of 94 FirstFirst ... 408085868788899091929394 LastLast
Results 1,336 to 1,350 of 1399
  1. #1336
    DK Veteran manocao's Avatar
    Sep 2009
    __________________
    China: OPEL Tech2 non-CAN multiplexer USB, OP-COM USB, OBDII Elm327 USB, VAG-COM 409.1/VCDS Lite 1.0 KKL USB
    Homemade: UNISCAN Visa 1.83 RS-232, Renault XR25PC USB, BMW KKL USB, Nissan Consult1 USB
  2. The Following User Says Thank You to manocao For This Useful Post:
    Col19 (31st October, 2019)
  3. #1337
    Home
    Hi, I have this PCB, needs any fixes ?
    Attachment 536555
    Attachment 536556
    Attachment 536557
  4. #1338
    Sep 2009
    It says version 9.0, please try on cars and tell, maybe they fixed it but i dont think so, it seems bad circuit as versions 5.0 to 8.0
  5. The Following User Says Thank You to manocao For This Useful Post:
  6. #1339
    Jun 2018
    Hi I have problem with my autocom cdp+.
    When I connect it to car( without laptop) It show blue light not white. And when I connect usb to laptop nothing happens, laptop dont see usb autocom... What it could be and what I can do? Also with bluetooth he can connect but then they ask for update and I cant do it...
  7. #1340
    Dec 2014
    PL
    Hi.
    Have you installed the drivers? Check in the device manager if the laptop can see the tester. It should be visible in two places:
    -Com port lpt
    - universal serial bus controllers
    If you have not installed, do it. They are in the folder with software (Driver).
  8. The Following User Says Thank You to Mario6 For This Useful Post:
  9. #1341
    Home
    and change USB cable, not use the china shit...
  10. The Following User Says Thank You to Domi For This Useful Post:
  11. #1342
    Home
    I tested my VCI but not connect to any car Next steep reflashed ARM = not connect to any car. I have FW for DS100E not for DS150E it is that problem ?
  12. #1343
    electronistul21's Avatar
    Nov 2011
    galati,romania
    you make test hardware?what mesage receive? TEST OK?I think no
    Carprog 8.21,xprog 5.55,galletto v54,kess and ktag rework
  13. The Following User Says Thank You to electronistul21 For This Useful Post:
  14. #1344
    Home
    with BT and USB all tests Ok ( tested on 3 Cars)
    Keep in mind, English is not my native language.
  15. #1345
    Nov 2011
    galati,romania
    in what car you try to connect? in car with k-line or in car with CAN?
  16. The Following User Says Thank You to electronistul21 For This Useful Post:
  17. #1346
    Home
    Car with K line
  18. #1347
    Feb 2010
    South Africa
    I have ver 3 without blue tooth, can I add bluetooth ?
    Do what you can with what you have .
  19. The Following User Says Thank You to ecufix For This Useful Post:
  20. #1348
    Dec 2014
    PL
    Domi
    Try on a car with CAN. I had such a tester before and did not connect with cars with the K line.
  21. #1349
    Feb 2010
    South Africa
    Quote Originally Posted by ecufix View Post
    http://www.digital-kaos.co.uk/forums...=1#post2035691
    so the answer is no
  22. #1350
    Jun 2018
    Hello,
    I have a problem with my diagnostics. I use a autocom cdp pro plus tool with autocom 2013 3. And I only can connect to cars which don't have an update from the old version. So i successfully connected to audi, volkswagen and a škoda, but unsuccessfully connected to two different model volvos. So the volvos had the update star next to them but audi, volkswagen and škoda didn't. So can anyone suggest a fix for this?
    Thanks!
