need buy trucks kit adapter.in this kit you have and adpter for trailler
Carprog 8.21,xprog 5.55,galletto v54,kess and ktag rework
thanks you
pass pls!!!!
hy!
i dont think to open another topic to my problem.
i have a band new, but clone autocom cdp+ with data logger.
1) installed delphi/autocom sw
2) installed device driver
2) win 8.1 pro see the device and com port
problem:
delph/autocom see the device, but cant test.
maybe just my fault, but i cant go forward this point...please help me anyone!!!!!!
I have Autocom with 2.14.3 software
I tried to connect to a 2008 Volvo xc60 with d544t6 engine. It does not response to engine connection but all the other like ABS, Immo etc. works.
Any idea?
UNI
gracias por compartir.
Hi guys, i have 2 lap tops with 2012 on first and 2015 on second. Today diagnose a grand vitara 2.0 hdi. Air con fault! 2015 had little info, but 2012 had lots and i found fault. But when i switch from one to other, i have to update hardware and test. Is this nornal?
Yes, it's normaly !
autoden (16th November, 2017)
USB Device Not Recognized ...
After some USB problem and repair I can`t use the autocom becouse I have USB Device Not Recognized an I don`t have idea what is it but the mark driver is USB driver ...
Thank you
Hi. To avoid every update in 2013.1, 2014.2, 2014.3, I have pasted the firmware (1423) from WOW Wurth 5.00.8.2 to everyone. Now my scanner works with 2013.1, 2014.2, 2014.3 and WoW Wurth. Delphi 2015.1 has a bit more new cars from 2015 but there is no description of errors. In my opinion, it's better to use 2014.2 or 2014.3 than 2015.1.
Col19 (31st October, 2019)
Hi.
Check the controller device manager 1) VCI (Diagnostic unit) and 2) Port (Com Lpt.) Try to reinstall both drivers. Check also in: details, device ID -VID and PID.
I have: FTDIBUS / COMPORT & VID-0403 & PID-D6DA. You can also check if MPROG 3.0 detects the interface. If the PID is for example 0000, the program will not detect VCI.
If it does not help, translate and read. Maybe you can find a solution to the problem.
http://autocom.ucoz.com/write.html
http://obd2-diag.blogspot.com/2016/0...141-20133.html
Please can you send me the password?
I have posted my problem on a new thread before reading this. It's here.
Could someone help me on my issue? My board is working but it doesn't connect with the ABS. Do I need to modify anything on the PCB?
