Peugeot rd4 to RNEG, some issues. - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 28 of 28
  1. #16
    Finland
    I just tested, you can actually have both displays:
    Allthough, i had to had rd4 temporarly in place to get clock & date correct, but it seems that everything works fine, of course all info messages now come to both screens.
    (Everything is just temporarly there, not properly installed, because i just tested if it works.
  2. #17
    Mar 2010
    Spain
    OK if you like it like this, with 2 screens...your choice
    Regards
  3. #18
    Finland
    I dont like it but seems its the only way to get ac info shown.
  4. #19
    Jul 2010
    Holland
    Nice DIY
    A rneg is an official option in the latest versions of the 407
    Those have also display of climate control settings on the colourscreen, not an extra display.
    It must be a setting in the BSI bij pp2000 to make it work instead of an extra display
  5. #20
    Finland
    I'll check those bsi and rneg settings with pps once o get my cable back, i loaned it to a friend recently and havent had a chance to check those settings. I'll report once i get that done.
  6. #21
    Finland
    Ok, this was just setting issue got it sorted with pps, rneg just required ac & clock enabled.
  7. #22
    Mar 2010
    Spain
    Quote Originally Posted by plagu View Post
    ok good
    Glad it's sorted
    Best regards
  8. #23
    Aug 2009
    This is interesting, does it not require more to get an rneg working in a 407?
    Can you write what wires needs swapping and what options needs enablng with pp2000 ?
  9. #24
    rneg board computer function
    Hi Everybody,
    I want to add to my car rneg (peugeot 307) and i have now soft without board computer and options to change language. Somebody know how to change flash? Where is stored flash memory?
    Here are pictures of rneg body
    ImageShack(TM) slideshow
    Btw it is other way to have one screen with clock, ac etc. It is necessery to have flash from rnego which have board computer normally. If someone tell me where stored flash i will read dump
  10. #25
    Finland
    Sorry for not replying sooner.
    I don't remember the pps settings (and cant check now reason below), but they are under bsi, and stated guite clearly, then you of course need to enter vin-code under "telematics" option in pps.
    wiring does not need any modifications if you use display from 3008/308, all fits straight in. If you use 407 original display then check pinout from Index - RT4 Wiki there is all needed info.
    michaelz? what do you mean "change languages"? there is language option under the setup? Also all the A/C, clock outside temperatures can be added vith pps without any flasing reguired.
    this is how my 407 is nowdays :/
  11. #26
    Jul 2011
    Hi Everybody,
  12. #27
    Finland
    all rneg's have same fw, those option are set with pps, just get hand of one, and you can enable those, no need to flash anything.
    btw. i have rneg from my 407 for sale (just head unit no display, as it got damaged in fire) but the headunit should be ok.
  13. #28
    anybody knows where is stored flash in rneg?
