Hi, need to get PIN from this dump. It's from Alfa 156 immo box 93c56 eeprom.
Thank you!
Thank you!
Hi Alfa BR same problem as the files posted on AO Files corrupt. Is this file from a working car?
Badger-,
Where can I buy a zed-bull? I've a few but they don't come with a OBD2 cable, is that right?
For the original Hickleys :: The Zed-Bull Transponder Machine . Obd2 cables can be added as you want them none of the clones have the obd cables available. If its mostly the alfa you want from the obd your probably better off with alfa obd as the cheaper option or MultiDiag from Actia they make the Fiat examiner dealer tools and multidiag offers virtually all the functions of the fiat examiner.
I was considering about a Chine clone, what do you think? I thought I've seen some clones with OBD2 plugs, but maybe not? There are no clones with obd2?
As far as I'am aware none of the clones have the obd cables. Even if they do you won't get any updates as it is the Alfa coverage isn't that great the only alfas that are covered are the 147,GT and Mito. The eprom functions on the clones only go up to 50 so you don't get the other 40 and still coming eprom modules. At the moment you would only be missing the Mito but as said eprom modules do get added for free
Hello again,
Could you please try if you can get the PIN from these 3 immo dumps?
Thanks in advance!
wrong read u read in circuit or out?
brchip (7th April, 2013)
Could you try again? Read them as 93c56A 8 bits.
No, this is from the immo box eprom 93c56. Alfa 156 2.0 TS 1999.
