New ZEOS & EDG-Nemesis 5.0 for ITGATE TGS220 - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 27 of 27
  1. #16
    May 2008
    Quote Originally Posted by deeboi View Post
    Just trying this Image for a change to see if it works, (mept1, you can change language to English by going to Menu>SetUp>System Settings>OSD Language then choose English.)
    I've got an ITGate TGC200 with a Sat tuner now installed works flawlessly with UKUR images but for some reason all EDG images refuse to move my dish, infact theres not even any power going to the motor at all as the buttons on the motor dont work and there's no lights on the motor at all but when I reflash back to a UKUR image again works perfectly, anyone else having this issue with this image?
    maybe i diden,t look hard enough...bit spoilt deeboi.....maybe no usals in the image..i,v only tried on a fixed dish....i may have to try again when i get time..look like i rushed my previous try.......
  2. #17
    May 2008
    Quote Originally Posted by handyguy2002 View Post
    hi guys
    doe's the above file work with the TGM220
    thanks in advance
    It does,...............
  3. #18
    Aug 2011
    yes, it works
  4. #19
    Aug 2011
    Merci pour ces informations
  5. #20
    Sep 2008
    can't get sound on this image... anyone else found a solution to this. tried reflashing and factory resetting. but no sound despite trying various audio settings confirguarations.
  6. #21
    hello guyz? does it work for tcm 200 ?
  7. #22
    May 2012
    hello guys? does it work for tcm 220?
  8. #23
    DK Veteran freck's Avatar
    Jul 2008
    Dark side of the Moon
    Read the posts above,it does work with the 220 but with a sat tune.
    Freck
  9. #24
    Top Poster Millzzy's Avatar
    Just to clear this up ( hopefully ) this image works perfect on tgs 220 , but not with tgm 220 ( even with sat tuner ) on the tgm 220 there is no sound as different drivers are used
    Sent from my HTC Sensation XE with Beats Audio using Tapatalk
  10. #25
    Oct 2012
    Default NooB
    I screwed-up the installation I have on the TGS220. Is it a good idea to install the New Zeos & EDG-Nemesis 5.0 on it... Or should I be less brave (or foolish). If so what do you suggest.
    Planning a serial update with Technomate Control Centre.... to fix it!
  11. #26
    Quote Originally Posted by SteveInBrussels View Post
    In what way have u screwed up ur installation , u might only need to do a factory reset
  12. #27
    Mar 2013
    Hello
    Is this possible to update from usb stick?
    Thank you
