New ZEOS & EDG-Nemesis 5.0 for ITGATE TGS220
Results 1 to 15 of 27
    DK Veteran freck's Avatar
    Jul 2008
    Dark side of the Moon
    Default New ZEOS & EDG-Nemesis 5.0 for ITGATE TGS220
    Thanks to Aguda over in SP...
    build by zeos for itgate tgs200, tgs210, tgs220
    enjoy with zeos v3 & edg-nemesis image.
    Havent tried it out myself yet......
    @ B~~~~...give it a try and see how you go mate.
    Freck
    p.s.
    I'll try to get latest url for this aswell if its not included.
    plasterer's Avatar
    Jun 2008
    Mersyside
    Just the image would do for now Freck .........Paul
    PAUL
    Jul 2008
    ...friend of mine just called in while uploading,all done now.
    Freck
    plasterer's Avatar
    Jun 2008
    Mersyside
    Cheers freck will down it and try it this week .................Paul
    PAUL
    Member Borgy100's Avatar
    Aug 2010
    Baile atha Cliath
    Hi guys.
    Not sure this image will work on my model. I have a TGC200 which was one of the early ones with swappable tuner. Any time I have tried to flash an image other than TGM220 I get the :wrong image for your model error TGS220:= TGM220??
    I found that by swapping tuners my box now thinks it is a TGM220 and these are the only images working for me. So after a lot of searching i came acroos the correct EDG NEmesis 4.4.1 image and the latest URL which gives acces to oanel with all add ons etc...am now running CCCam 2.2.1 like a dream. Thanks for all the help guys.
    Keep up the good work...we've come a lon way since the SK cable scene!
    B~~~~100
    May 2008
    Quote Originally Posted by B~~~~100 View Post
    Hi guys.
    B~~~~100
    I had the same issue when trying to flash with itgate control centre.....You have to ftp the image into the temp folder and rename the imaige "update.img" then manually instal it.
    This image has everthing you need
    plasterer's Avatar
    Jun 2008
    Mersyside
    Hi mept ,
    you running this now on you STB
    wots the EPG like ..............Paul
    PAUL
    May 2008
    Quote Originally Posted by plasterer View Post
    Hi mept ,
    Hi plasterer...just messing with it at the min....will give you a full sp later
    May 2008
    1.Epg the same as the other itgate images.. if not worse
    2. No option to change the language from french to english
    3. No volume. flashed 3 times factory reset still no volume
    4. The postive thing is it has every thing in this image to get you viewing
    Nice to try another image,but i,v gone back to edg-nemesis4.4,..just glad i remembered to back it up before i tried this image
    Jul 2008
    Have ye tried the Weekepg plugin on the ITGate yet?
    I used it on the TM500/600 using the UKUR image and it works fine,needs to be configured first and you can get a weekepg list from tonedeff @DW and is updated regular.
    @Plasterer...might be worth a go Paul if you need better epg.
    Freck
    May 2008
    Thanks for the pm freck...never new that was knocking about
    May 2008
    Quote Originally Posted by freck View Post
    Freck
    Tried on edg-nemises4.4 no improvment ....but a massive improvment on urukv9 get now and next on all channels....
  13. #13
    Jul 2008
    You should get a lot more than now and next...I'm on hold at the moment so will look into this further when I get back.just popped in for a quick browse.
    Sent from my HTC Wildfire using Tapatalk
  14. #14
    Feb 2009
    Just trying this Image for a change to see if it works, (mept1, you can change language to English by going to Menu>SetUp>System Settings>OSD Language then choose English.)
    I've got an ITGate TGC200 with a Sat tuner now installed works flawlessly with UKUR images but for some reason all EDG images refuse to move my dish, infact theres not even any power going to the motor at all as the buttons on the motor dont work and there's no lights on the motor at all but when I reflash back to a UKUR image again works perfectly, anyone else having this issue with this image?
  15. #15
    hi guys
    doe's the above file work with the TGM220
    thanks in advance
