Page 2 of 7 FirstFirst 1234567 LastLast
Results 16 to 30 of 104
  1. #16
    England
    Quote Originally Posted by pecky View Post
    It could be hiding very well, but I can't see anything that matches how the code is stored in the 95160.
    If I get brave I will have a go on mine, but as keyless entry onces don't come up 2nd hand, it could be expensive if anything gets corrupted.
    Password please ! Thank You! ................... or PM
  2. #17
    Jan 2011
    hi friends
    please i need your help shortly
    i have astra h (open&start) CIM with MCU(9S12DG256)
    i bought it as new during programming i entered wrong pin code(4564) when the CIM check it with ECM and peps ECU it give me massage programming failed
    when i go to reset this CIM via code (4564) it give me massage wrong security code
    after that i read pin code from ECM by nasratech tool it give me code (2791)
    now the problem is the CIM did not accept pin code (4564)
    the CIM locked
    are you have dump with pin code for CIM which content (9S12DG256)?? or any idea
    Excuse me my bad english - its not my native language
  3. #18
    Quote Originally Posted by ahmedezz View Post
    hi friends
    the CIM locked
    Well I know this is probaly too late to solve your problem but Im just now reading this post, I have something to say about your issue that can help you and others in the future
    If you enterd the code with op com then probably it has swapped the code in the CIM its happend to me also and after lots and lots of research I managed to disover that code in the CIM was enterd like this.
    EXAMPLE : You enterd 4564 in a virgin CIM and it was accepted ok after a recycle of the ignition you re enter the same code 4564 for programming or coding or what ever and you get wrong code enterd, Its beacause CIM has stored the code swaped and is now recodnized like this (5446),I think its some bug in op com that has not been discoverd and fixed by developers.Any way to get done with this you
    need to enter your code swapped so CIM can see it propaly.So let say our ori code is like our friends here 4564 you need to enter it 5446 and all will be ok.
    ENJOY GUYS !!!!
  4. The Following User Says Thank You to PAVLOS2 For This Useful Post:
    barho67 (2nd January, 2019)
  5. #19
    I want to fit second hand CIM module on Astra H.
    I need pin code from dump for reset it.
    Ive read dump from 95160 eep.
    Quote Originally Posted by joubliss View Post
    read again ur dump has 2064kb must have just 2048kb.
    Corrected
  6. #20
    joubliss's Avatar
    Far away
    Quote Originally Posted by ruleczka View Post
    *No Help For Leechers
    Press THANKS button if my post was Helpful
    All my Files are Protected with Password
  7. #21
    Corrected
    Fixed at 100% ok
  8. #22
    Corrected
    Here you are
  9. #23
    drakov's Avatar
    Aug 2008
    Pecky do you have any plans to sell your software? I know a while ago you said you where going to look at securing it and possibly selling it...
    Check out The Number 1 Resource for all Automotive Software with a lot of patience you like me will find what you need...
  10. #24
    Meat-Head's Avatar
    Quote Originally Posted by drakov View Post
    OR as selling is against DK Rules, simply handing it out for free?
  11. #25
    I know it would get cracked and will end up on here no matter what I do to protect it.
    That will then just end up with ebay full of people offering decoding for ?10 or ?20 as they currently do with the software aquer posted on here after I put the algo for CD30 MP3. Can't complain though as he helped me start my software off by showing me how to load in the bin and interrogate it.
    Every item I can calc for I have personally bought the parts to learn how to do it and then spent hours doing so.
    I Know DK is all about sharing, which is why I will give the codes out, but the whole software is another matter as I'm not sure it makes business sense for me to do so at the moment.
  12. #26
    Meat-Head's Avatar
    cool, you got a link to what your refering to please?
  13. #27
    http://www.digital-kaos.co.uk/forums...-guide-172375/
    Although I lost the image during a server change, SITI has posted the same table I worked out in the thread
  14. #28
    Timisoara
    Default Pin from cim or navi CD70
    Hello
    can have pin for cim
    Thank you
    edit
    i read the radio eep
    Please \
    edit: do your home work
    1144
  15. #29
    I need pin code from dump for CIM ASTRA III.M95160.zip
    Oh and by the way if my post has been at all helpfull it will encourage me to respond to posts if you remember to please press the little red Button
  16. #30
    Quote Originally Posted by __nero__ View Post
    2317 is your code
  17. The Following User Says Thank You to pecky For This Useful Post:
    __nero__ (6th April, 2013)
