Results 16 to 30 of 40
  1. #16
    Chile
    Default UPA original V1.1
    Hi all friend
    My original UPA worked fine about two year.
    Please can you help me, I am looking for solution for upausb 1.1
    When start the programm give me message:
    upa usb connected ,programmer not found 1001.
    here is my dump
    Best Regards
  2. The Following 2 Users Say Thank You to LATTINO For This Useful Post:
    djramo (13th March, 2022), pintobraz (2nd August, 2014)
  3. #17
    ovi_dk's Avatar
    On board
    Try to use the file from first page from this topic,write in 24c128 and try,if u have the same problem,loock to your driver,if its 3,4 reinstal and use driver from version 1,1
    Good Luck!
    If u have the answer say Thank You!!
  4. #18
    Chile
    Quote Originally Posted by ovi_dk View Post
    Good Luck!
    I do it, is the same dump, cero diferences
  5. #19
    Tereksaz's Avatar
    Nov 2010
    Dark side of the Moon
    Quote Originally Posted by LATTINO View Post
    Hi all friend
    here is my dump
    Best Regards
    tell me your serial number UPA original 1.1?
    I am try to help.
  6. #20
    didi_du_93000's Avatar
    France Paris
    I have UPA USB from china.
    It's version 1.1.
    I have tryed to use with vsoftware version 1.2 and now my programmer don't work.
    I think when i have tryed the 1.2 soft my programer was automaticly updated and then locked.
    I have tryed all dump from DK for 24LC128 but always same problem.
    I have error " Programmer not Found 1001 "
    Anyone can help me please?
  7. #21
    pepesound's Avatar
    Bulgaria-Radomir
    my UPA original work 6 yers perfekt
  8. #22
    France Paris
    I have solved my problem with dump from this thread and with old driver.
  9. #23
    Dec 2010
    Quote Originally Posted by didi_du_93000 View Post
    upa clone, works well, you read memoirs? I recommend to buy?
  10. #24
    Aug 2011
    Default upa damage
    hello friends, I have two upa usb and both are faulty. both when I connect the usb port are recognized by the program, but when I use the voltmeter current ranges until the 12volts and 16 volts. someone can help me with this fault? Thanks and Regards
  11. #25
    hello there ,,
    anyone can share the old Drivers and old Software after revive ,, I lost my CD ..
    then I try to use 1.2 and it will damage again ..
    thanks a lot ..
    Regards,
  12. #26
    Apr 2012
    Default Upa 1.1
  13. #27
    Default appreciated
    Quote Originally Posted by pezao View Post
    Thank you very much about this ..
    Appreciated
    Regards,
  14. #28
    Top Poster sanjaycip's Avatar
    Jul 2011
    Tondo, Manila
    i have all version of hcip calculator
    want to try one?
    Light travels faster than sound...This is why some people appear bright until they speak....
  15. #29
    Quote Originally Posted by sanjaycip View Post
    want to try one?
    can you share?
  16. #30
    What is difference between original and clone?(beside update)
    BR
