Results 1 to 15 of 27
    Default AM29BL802 pinout to Elnec Labprog
    I have Elnec Labprog 48 (ZIF 48) and i need to program one AM29BL802 but i don't have adapter.
    Can somebody give me the schematics so i can connect it?
    I only need to program one AM29BL802, i don't need to build adapter. Is it possible to connect just the necessary wires to Programmer?
    Thanks in advance
    If you search the forum, I started exactly the same topic as yours 1 year and 25 days ago. Almost to get a solution but not!
    I think that's not easy you make all wire connections, too complicated and too narrow pitch. Look at my that thread, I put an example diagram of an Elnec adaptor there. that's just for a 32 pin device and not 56 pins like this.
    I've seen, but it was for beeprog, and the zif socket is only 40pin. That's why i created a new thread.
    Maybe someone can help us...
    250eur is a robbery for an adapter, to use one or two times.
    I think we both have ZIF48, is the wiring of adaptor #70-0099 you looking for?
    Quote Originally Posted by Zmann View Post
    I have DIL48/SSOP56 ZIF Flash-2 70-0099 Elnec adapter.
    I need some time to check all wire connections to write schematics.
    I hope two days will be enough.
    Sorry, too much work just now.
    Thanks a lot for your good intention of helping us.
    I'm looking foward for your reply.
    Thanks in advance
    DIL48/SSOP56 ZIF Flash-2 70-0099 pinout
  8. The Following User Says Thank You to Room For This Useful Post:
    karzan1977 (7th December, 2019)
    Many, Many, Many Thanks!
    R1, R2, R3 - The 3 resistors connect to pin 36 of dil48?
    Best Regards,
    P
  10. #9
    Quote Originally Posted by paraver View Post
    Best Regards,
    P
    Yes. I think pin 36 of DIL48 must be Ucc
  11. #10
    you can read with flash programmer this flash but file is crypted
    best is use BDM
    if no use BDM and use flash programmer you need use DECRYPTOR CRYTOR
    here is
    PLease Click to Thanks
  12. #11
    I don't need to read it, i just need to write it.
    It was a bad galletto write, but i have a dump that i'd already read it.
  13. #12
    Some ECU has mixed data lines for the convenience of the trace.
    Bosch and Siemens are different in trace.
    You may need to convert dump before write flash with programmer.
  14. #13
    Thank you Room, what file extension is it.
    Quote Originally Posted by Room View Post
  15. #14
    It is simply TXT file.
  16. #15
    I think I have a problem with ZIP, just rename the unzip file with .txt but the file is not readable
    Can you help to resend in .rar thanks
    Ok now, no need a .rar uploading, I change the browser and it works.
