Livefootball version 2.0 enigma2 plugin - Page 2
Results 16 to 30 of 33
  1. #16
    Nov 2008
    LiveFootBall 4.1
    updates :new startup logo
    -fixed soccer on satellite
    installation:
    by manual method from attached file
    -Tspanel -addons
  2. #17
    Feb 2012
    thanks for this, great plugin.
    Is it possible to zap to the channel on the "soccer direct feeds" menu instead of having to write the details down and enter them in manually to scan for?
  3. #18
    Nov 2008
    Quote Originally Posted by evesham View Post
    yes thanks for the suggestion
    zap to channel available in soccer on satellite so i can imported to soccer direct feeds
  4. #19
    Oct 2008
    Can some one in plain English explain to me how I install this on my DM800 USING DREAMBOX EDITor Filezilla.Thanks
  5. #20
    Nov 2008
    copy the ipk file to tmp folder in dreambox
    if you have TSpanel open tools-1 and file explorer and go to tmp folder and click the file
    or if you have telnet program write this command after connecting with dreambox
    opkg install /tmp/enigma2-plugin-extensions-livefootball_4.1_mipsel.ipk
    restart gui and look in plugins for livefootball
  6. #21
    Jun 2011
    I've got livefootball 4.1 plugin installed but when i goto the middle icon (soccer on satellites) I get error message "error processing data, please update liveonsat url from about & updates option and try again"
    When I goto about and updates it says "no updates available"
    I've uninstalled and reinstalled and still got same problem.
  7. #22
    Mar 2012
    Belfast - Northern Ireland
    Default TM800HD
    Would this work on a TM800HD ?
    I tried installing but got the following error
    -sh opkg: not found
    Its tef in /tmp/
    Any ideas ?
  8. #23
    Nov 2008
    version 4.2 for eo2.0 and oe1.6 images
    updates;
    -fix soccer on satellite
    -fix minor bugs
    installation:
    -from previous version-update for oe 1.6 images
    -TSpanel servers-plugins
    -by manaul methods
    download
    Livefootball-oe1.6_4.2_all
    Livefootball-oe2.0_4.2_all
    have fun
    mfaraj57-2012
  9. #24
    Nov 2008
    Quote Originally Posted by grahampaull View Post
    -sh opkg: not found
    Its tef in /tmp/
    Any ideas ?
    i do not know about tm800 but if it is eni
    gma2 then the plugin should work
    opkg is not found,this is problem in opkg system try to see how the packages installed for this model,try to use ipkg install /tmp/plgunname
  10. #25
    Nov 2008
    Quote Originally Posted by Ettrick View Post
    try update to last version 4.2
    source site liveonsat keep changing its address
  11. #26
    The ultimate update - adding live streams of games If only! haha
    Great app though, thanks!
  12. #27
    Junior Member redone's Avatar
    North West is best!!
    Great Plug in mfaraj57 you are one clever dude..
    Is there any way for a sad Everton supporter to edit the rss file for some news from goodison park?
    Thanx again man
    Ok Sussed it thx...
    FYI edit the feeds.xml with your teams RSS which is located in...
    /usr/lib/enigma2/python/Plugins/Extensions/LiveFootBall
  13. #28
    Jun 2011
    Quote Originally Posted by mfaraj57 View Post
    I've updated to 4.3, now i get error "Website server failed to handle your request! Check liveonsat.com from another device"
    I checked liveonsat.com from PC and it loads.
    In livefootball settings liveonsat url is http://liveonsat.com but the homepage of liveonsat is http://liveonsat.com/daily01.php
    EDIT. It's working now
  14. #29
    Can't get this to show up under plugins at all (have installed livesoccer1.7 in the past)
    Tried both copying "enigma2-plugin-extensions-livefootball-oe2.0_4.3_all.ipk" using both DCC & Telnet
    Then going to Dreambox receiver and pressing Green Button, Yellow Button, Manual Install IPK files & then installing.
    I get an error message 211 and the box tells me that numerous flag.gif are already installed
    When I go back to my plugins, the Livefootball plugin is nowhere to be seen
    My image is Nabilosat Enigma2 Black Hole - DM800 v0.12
    Any help would be appreciated
  15. #30
    Sep 2010
    Guys
    In trying to zap to channel but can't seem to do it
    Soccer on say brings up what's on today but won't zap
    Soccer feeds has nothing in it
    Any ideas what in soon wrong ?
