Results 1 to 13 of 13
    V.I.P. Member dell_xps's Avatar
    Default How to stream from the VU+ Duo using web browser & VLC
    [ame=http://www.youtube.com/watch?v=IPChZ1zbOVk]YouTube - ‪Streaming from the VU+ Duo‬‏[/ame]
    How to stream to any PC using the web browser & VLC.
    Any questions just ask.
    In the video I just streamed BBC 2 (SD) :-)
    [ame=http://www.youtube.com/watch?v=hfShnrFYixw]YouTube - ‪Vu+ Duo, Vix 2.2, Enigma II‬‏[/ame]
    Bored this morning so had a wee play about on iMovie, took about 5 mins...
    Newbie delahmed's Avatar
    Jul 2011
    London
    thanks it worked!
    Feb 2012
    Sorry for old reply..
    But can't get to the HTTP interface on my vu+ duo running vix 2.3.204
    FTP, telnet, SSH all work
    but not HTTP
    is there anything I need to do to enable it?
    Many thanks
    Member Lewiscc's Avatar
    Apr 2011
    Edinburgh
    Quote Originally Posted by nakeddave1 View Post
    but not HTTP
    Many thanks
    hi dave ... you either need to configure the openweb interface in plugins ... or disable it and download the old webinterface which should work the same as previous vix images.
    Feb 2012
    FYI they changed the http port to 8088
    Should of just changed the port to 80 m8 :-)
    Mar 2011
    Sweden
    Which port should be opened? I can not access the vu + duo? Only with ftp no other program or web. What should I do?
    Install samba and set the webif plugin to port 80.
    Oct 2010
    hi
    i have just purchased a solo2 and have it up & running using vix image with 1tb hdd installed and 2 sat inputs 28.2e & 19.2e.
    i have been able to stream hd channels to wireless laptop through the webif and it was pretty much flawless.
    my query is regarding streaming to another linux box for the purpose of watching the solo2 in another room.
    my other box is an ipbox 900hd which i have a sifteam image in flash and several e2 images on usb stick. i have the ipbox connected to my router for testing purposes directly with a patch lead,(i have a cat 5 cable from router to 2nd tv room)
    i found a plugin called partnerbox in (1.0) in hdmu e2 image and managed to view pictures and control channel zap on the solo2 via the ipbox but the results were very unstable and the e2 image on the ipbox crashed more often than not.
    does anyone have any knowledge of this plugin or whether the problem is because the ipbox is sh4 (though running e2 and plugin downloaded and installed from panel).
    also is there another way to achieve this using the network between the 2 boxes?
    pleas accept my apologies for my basic networking knowledge.
    h
    Jun 2009
    Quote Originally Posted by dell_xps View Post
    YouTube - ***x202a;Streaming from the VU+ Duo***x202c;‏
    can you watch different channels from the box downstairs and the pc upstairs? i can only watch same channels as upstairs or downstairs
    Jun 2009
    Quote Originally Posted by hambone View Post
    hi
    h
    can you view different channels or same channels. i can only view same channels. please tell how you did this please
  13. #13
    You must have transcode enabled on yer box, or you dont have a twin feed going to yer box m8.
