Fiat Examiner cd 7.70 need activating
Page 1 of 5 12345 LastLast
Results 1 to 15 of 64
    Top Poster wiggyshome's Avatar
    UK, ESSEX
    Default Fiat Examiner cd 7.70 need activating
    hi Arturasi
    can you please help with activation of software Please
    id code
    K17UE-B2FC7-0S413-390F4-O5B2A
    thank you
    wiggyshome
    Quote Originally Posted by wiggyshome View Post
    hi Arturasi
    id code
    thank you
    wiggyshome
    N2N40-8GE8R-9153D
    UK, ESSEX
    thank you
    going to try it now will let you know in a min
    wiggyshome
    UK, ESSEX
    thank you
    wiggyshome
    hi all works good thank you
    thank you for your quick help
    wiggyshome
    drakov's Avatar
    Aug 2008
    wiggy what interface are you using? or did you pick up a used examiner from somewhere
    Check out The Number 1 Resource for all Automotive Software with a lot of patience you like me will find what you need...
    Default fiat examiner
    What is the latest verion of examiner . can someone please upload and send me to PM.
    hi Arturasi
    can you please help me allso with activation of software
    id code
    M05I2-J54C5-1U510-370E5-M1F2E
    thank you
    kaosos01
    Nov 2011
    aturasi. smart guy. wiggy is a very helpful chap
    dunkler's Avatar
    May 2009
    Hatzfeld
    Can i have a key for the following code:
    P1?W?-I??D?-6D413-400R4-K4D0C
    Thanks in advance
    yellowstilo's Avatar
    Quote Originally Posted by dunkler View Post
    Thanks in advance
    this one will never work because the code is incomplete (??) - you probably installed it on a laptop without the proper hardware instead of a genuie Examiner tester....
    dunkler's Avatar
    May 2009
    Hatzfeld
    Thats what i thought first, i knew HWID can't be with ? mark, but i installed on Actia Examiner HD, strange
    in that case the Examiner probably can't find part of the hardware - can't help you with that.....
    Did you change anything on the Examiner tester?
  13. #13
    dunkler's Avatar
    May 2009
    Hatzfeld
    No but i notice that touchsceen isn't working, tried both with win98 and xp embedded. Today I installed win98 using recovery and no response from touchscreen, maybe is defective?
  14. #14
    might be, you can check the connection of the flatcable inside....
  15. #15
    dunkler's Avatar
    May 2009
    Hatzfeld
    The flat cable seems to be ok. Also i notice the HWID changes everytime i open setup.exe. Also BIOS is password protected
