Huawei E5830, E5832 & E5838 Free Unlock - Page 33
Page 33 of 33 FirstFirst ... 23282930313233
Results 481 to 494 of 494
  1. #481
    Junior Member andycast's Avatar
    May 2009
    Great tutorial, finally managed to unlock my e5030, I need advice on what to do next, can I install any network sim and it should work? Also will I need to flash new firmware to install a generic dashboard/ui for universal network tethered use?, great work, thanks in advance.
  2. #482
    Dec 2013
    I got the Huawei e5223 but I need an unlock code for it. I can't do the tutorial at the start as I use it for my phone. It is a hotshot wireless device. Any help would be greatly appreciated and would save me from having to buy a diff one. Thanks in advance. Lisa.
  3. #483
    Western Cape, South Africa (Ex-UK)
    Quote Originally Posted by Lisac13 View Post
    Are you sure this isn't a E5332? Any way, if it's post 2012 then you can't read the codes...
  4. #484
    Dec 2013
    Oh it is actually, sorry I'm dyslexic, all always put things in the wrong order
  5. #485
    Dec 2013
    So is the only way to get it unlocked to get it from o2 after spending the credit?
  6. #486
    I have used these people who charge ?3.99 per code.
    Just make sure that when you pop in the wrong SIM that it actually asks you for the unlock code.
    If it does, then go to Huawei Unlock by IMEI and fill in the model number and IMEI.
    They do the codes manually but it is usually within 12 hours or so.
  7. #487
    Dec 2013
    Jim. Thank you so much. I'll will give them a go and I appreciate you taking the time to help me. Happy Christmas. Lisa.
  8. #488
    Dec 2013
    Code worked perfectly, thanks for processing it so quickly Jim. And you were very reasonable, only?3.99. I have recommended you others already.
  9. #489
    Mar 2014
    Unlocking and flashing E 5832 S with a firmware that let me change APN:
    1. I used QCMobile****ysisToolV5.06 for reading EFS
    2. I found the unlock code with ExtractText, form me was the first code from the column
    3. I could't enter the code using CardLock_Unlock because didn't detect my modem.
    4. I decided to enter the code using the web interface. WORKED PERFECTLY.
    5. I flashed my device with this firmware WLE5832S3095001_ALL_VERSION_V100R001C365B311_USB
    from here: https://mega.co.nz/#!bwxC2KyJ!M4TtCR...44P0phtuDor26o
    6. Here is the forum where I found the firmware HUAWEI E5832s cant repair - GSM-Forum
    I'm from Romania and I tested my device with 3 different networks: RDS, ORANGE , VODAFONE
  10. #490
    Oct 2012
    Northern Ireland
    I need to know if theres an unlock code for a 3 Network Huawei E585 or could someone post the latest DC unlocker client for doing this?
    Thanks In Advance
    IEMI 352398043386186
  11. #491
    Canker_Canison's Avatar
    12th Level of Hell
    Quote Originally Posted by Frogger View Post
    Thanks In Advance
    I don't have support for this modem. But I do have support for the E585u-82 & E585v2, both produce the same code.
    Try it if you wish....
    Code : 31031037
    Canker
    "Animal, vegetable or mineral... I'll do anything, to anything, with anything"
    - The Baby Eating Bishop of Bath & Wells
    [COLOR=Green]
  12. #492
    Jul 2014
    e5832 NetCom WLC1GCPU
    https://www.sendspace.com/file/4r6wk7
    Please unlock code.
    imei 354104030758280
  13. #493
    Oct 2017
    Default Huawei E5830 E5832 E5838 Free Unlock
    Just wondering if this hack still works and is current??I'm pretty sure I have a Huawei E220 on "3 UK Network" somewhere and would like to use it if I can get free internet on the moveWould appreciate someone confirming
  14. #494
    Sep 2018
    need help unlocking my huawei E5830s
    I extracted the efs but was unable to udentify the 8 digits passcode
    It would be very appreciated if u can help me
    thank u
