Huawei E5830, E5832 & E5838 Free Unlock - Page 3
Page 3 of 33 FirstFirst 1234567813 ... LastLast
Results 31 to 45 of 494
  1. #31
    Western Cape, South Africa (Ex-UK)
    Quote Originally Posted by lapiovra View Post
    at last! please take a look, which code is correct.
    Your file is not big enough! When decompressed it should be around 700K in size!
    Run through the procedure again step by step!
  2. #32
    Nov 2011
    Default Troubles with unlock
    Hi there
    now I have different problem. When I'm trying to read ESF, just after typing name of file and pressing Save, QMAT crashes. I tried three different cmputers with Win7 and Win764, but no result. Newer version of Qmat ? RevSkills ? works, but can't connect to modem. Any good idea about it?
    Brg, Lapiovra
  3. #33
    Nov 2011
    Default after couple of tries...
    RevSkill gave me those results ? no unique figure inside
  4. #34
    Nov 2011
    Default And in the end...
    So, I've updated firmware!
    after that QMAT worked and gave result. But inside SO MANY different 8 digit numbers... plz, help
  5. #35
    Nov 2011
    one of those
    31223201
    32265545
    04670057
    11470734
    04638780
    68264234
    15408502
    22428509
  6. #36
    Your code should be: 22428509
    Try once and post the result!
  7. #37
    Nov 2011
    Quote Originally Posted by Jim.Mahoney View Post
    Good, sehr gut, Woldemar. It's unlocked now. Thank you very much.
    But data connection is not working. 3G connected, no data. Looks like old operator data is not compatible with other one. And in the web interface no sign of setup. Any advice?
  8. #38
    You'll need to flash generic firmware to it or use it via USB. The web interface is often disabled on branded devices!
    Be aware that this will almost certainly void your warranty!
    All the files you'll need can be found here:
    DC Files - Huawei E5832s
  9. #39
    Nov 2011
    HI many thanks for this thread , I worked great ( first 8 bytes decimal found with 0101 preceding
  10. #40
    Nov 2011
    Hey there. I've searched through the extract, but after trying two codes that didn't work, I though I'd put the extract up here to try and get a better result.
  11. #41
    Quote Originally Posted by diocesan View Post
    Your file is too large!
    I'm guessing you've read the device incorrectly!
    Retrace your steps it should be around 700K or so!!
  12. #42
    Nov 2011
    Hi Jim,
    Thank you for the prompt reply! I've retracted my steps (twice). The resulting file on both occasions is 1.56MB.
    Is this information of any assistance?
    Device: Huawei E5832S
    Network: O2 (Ireland)
    IMEI: 354104033053143
    Software version: 956.11.88.04.309sp01
  13. #43
    Hi Jim,
    The information is of no use as calculators do not work!
    I suggest that you try on another PC ideally with Windows XP 32bit running!
    Ensure all modem dashboard software is closed down and re-run the procedure.
    We have successfully unlocked quite a few E5832S, I we know it works!
  14. #44
    Nov 2011
    Thank You
    finaly it?s really easy to get the code with your description. With the ExtractText Program I found the Code on the first attempt for my HUAWEI 5832s.
  15. #45
    Nov 2011
    The QMAT version I have has errors during read EFS...
    Network: Globe (Philippines)
    IMEI: 354104034366445
    Software version: 956.11.109.02.309sp01
    Do I need to change software version to : 956.11.17.05.309 from (E5832sUpdate_956.11.17.05.309.zip) so that QMAT will work?
