Huawei E5830, E5832 & E5838 Free Unlock
Page 1 of 33 12345611 ... LastLast
Results 1 to 15 of 494
    Western Cape, South Africa (Ex-UK)
    Default Huawei E5830, E5832 & E5838 Free Unlock
    This is a bit lengthy but it should produce your E5830, E5832 or E5838 unlock code for free!
    Always REMOVE the SIM card before doing the read or you may get an corrupt file!
    Instructions:
    Download this version of QMAT.
    Digital Kaos - Downloads - QMAT
    Select the Application port of the E583x. Check in Windows Device Manager if unsure.
    To test if you got the right port, send the "00" version command.
    You should see something like this:
    00 4A 61 6E 20 20 35 20 32 30 31 30 31 35 3A 31
    38 3A 30 35 4A 75 6E 20 31 32 20 32 30 30 39 30
    35 3A 30 30 3A 30 30 53 4E 43 41 41 4C 5A 4D 00
    00 0D 00 00 00 01 B1
    .Jan..5.201015:18:05Jun.12.200905:00:00SNCAALZM... .....
    Then select: Read EFS and flag "Alternative Method".
    Click "Let's go".
    The resultant file contains both Binary and ASCII characters.
    You will need to search for this for your 8 digit unlock code. There will be two codes in the file one is for removing the SIM lock and the other removes the Mi-Fi lock.
    You can use Notepad to search the file, its crude but you should find the code in a few minutes. I have tried a program called ExtractText:
    Windows 95+ programs
    The results are hit and miss with this program, sometimes the code is on the last line sometimes it is at the top of the list! However, it might give you a good idea of what you're looking for! To cut down on unnecessary searching using Extract Text go to Options and then Text Options and set the parameters to: Minimum Character 7 and maximum characters 8 plus you should have only Numbers selected:
    One thing to keep in mind, the unlock code will appear only once so you can ignore repeated codes. This should narrow the search down somewhat!
    Example:
    Do remember that you have 10 attempts to enter the correct code so do take a little time to chose the code!
    A code entry to is included below....
    If this seems complicated please ask someone else to do the task for you!
    Please post your results!
  2. The Following 5 Users Say Thank You to Jim.Mahoney For This Useful Post:
    jackit (11th April, 2013), n0kru (13th November, 2013), NEWBY12 (6th March, 2024), seal777 (8th August, 2021), tomsk (5th June, 2013)
  3. #2
    This should provide some extra help:
    Code viewed in Notepad:
    Code viewed in Hex Editor:
    It is worth noting that every modem I've come across so far, the correct 8 digit unlock code is preceded by Hex value 01 twice.
  4. The Following 2 Users Say Thank You to Jim.Mahoney For This Useful Post:
  5. #3
    Aug 2011
    please post code for my E5832S
    Thanks a lot
    e5832s.zip
  6. #4
    Quote Originally Posted by faxm0dem View Post
    Thanks a lot
    e5832s.zip
    Unlock code: 34093944
    Sep 2011
    need help unlocking my huawei E5832s
    I extracted the efs but was unable to udentify the 8 digits passcode
    It would be very appreciated if u can help me
    thank u
  8. #6
    Quote Originally Posted by cyrusthevirus View Post
    thank u
    Try: 12435757
    Then post the result...
  9. #7
    Sep 2011
    Quote Originally Posted by Jim.Mahoney View Post
    Try: 12435757
    Thank u worked like the a charm
    u are the man, thanks for ur help
  10. #8
    Sep 2011
    It works like the a charm. Really very helpful.
    For information: i follow your instruction:
    My password code is the 1st code when i use ExtractText.
    And also
    Very thank again.
  11. #9
    Oct 2011
    Default Need code for Huawei E5830S
    need unlock code for E5830S
    anyhelp will be appreciated.
  12. #10
    Quote Originally Posted by mani23 View Post
    Read the first post in the thread....
  13. #11
    Oct 2011
    did it
    found it right at the top, but 01 01 hex values were there.
    Also special character was there after the code.
    Thanks for all the help
    Mani
  14. #12
    Oct 2011
    How can I get the code myself?
  15. #13
    Quote Originally Posted by KOUSHIEN View Post
    Read the ******* first post in the thread!!!
  16. #14
    Oct 2011
    After reading the SIM unlock code from the device, how can one apply this code? Inserting a SIM from another operator should trigger the request for the unlock code? I'm trying to unlock a Huawei E5832S.
  17. #15
    Quote Originally Posted by telece View Post
    Read the first post! There is a tool included!!!
  18. The Following User Says Thank You to Jim.Mahoney For This Useful Post:
