Mercedes Truck Base Low - showing "BLOCKED"
Blaupunkt 7 620 000 020
Eeprom = 95320
Can anyone reset the counter and supply the code.
Thanks.
Eeprom = 95320
Thanks.
V Series TMS470 / EEPROM data - encryption / decryption, totally pwned.
IEC 62056-21 - new discussion: sonsivri.to/forum/index.php?topic=60412.0
Anyone ?
It must be the same sort of thing as the 7620 000 044 ?
code is 1136
Thanks for that. I had an idea that was the code from some writing on the set but its the timer I need resetting - it says "Blocked" on the display.
try this resetted but im not sure
Thanks, but the resetted is the same as my original.
I left the radio switched on for a couple of hours and it eventually let me enter the code. I'll take another reading and post the unblocked dump for reference.
Thanks.
At last. Here's the dump :-
Eeprom = 95320
Code = 1136
cubica1 (26th May, 2016)
Hi evrybody!
I'd like to know the code for Mercedes MB Truck Base low truckradio!
815 BP0020 8 0615207
034953 MB Truck Base Low
A 000 446 10 62 ZGS001
Thanks,
Gregory
This was very quick!!! )
Thanks!
If not secret, how can I calculate the code from the dump?
If you think, write me a PM.
ilkovelichkov (25th April, 2019)
Thank you a lot!
I got it too
Hi !
I need code from dump. Radio is BLOCKED.
Thanks!
