Quote Originally Posted by will12345 View Post
hi all,
not sure if any one here can help me but worth a go.
alright i have just bought a late 2010 kenworth T408SAR
to pull doubles up the hwy it has about 100,000 k's and no power everything mech wise is great just running a 525hp program with 1850fpt any one have a program with a little more hp and 2050 fpt dont wanna go to high coz it already runs warm as it is any help would be appreiciated
many thanks in advance
great forum guys keep up the good work!
I had a similar problem but it turned out to be the fuel pump but there was no fault code 2215. The fault code then appeared after a while...
Reason:
Fuel Pump Delivery Pressure - Data Valid But Below Normal Operating Range - Moderately Severe Level. Low fuel pressure has been detected by the ECM.
Effects:
Engine may not start, emit white smoke, run rough, or lose power.
i hope this helps
