it works can be possible add a second j2534 tell me so it show either one or i have o do a new key for it
this is the registry for the all2flash
[HKEY_LOCAL_MACHINE\SOFTWARE\PassThruSupport.04.04\ Drew Technologies Inc. - CarDAQ PLUS]
"Vendor"="Drew Technologies Inc."
"APIVersion"="04.04"
"DeviceId"=dword:00000259
"Name"="CarDAQ PLUS"
"FunctionLibrary"="C:\\\\WINDOWS\\\\system32\\\\dg Flsh32.dll"
"ConfigApplication"="C:\\\\Program Files\\\\Flash2Console\\\\Flash2ToolConfig.exe"
"CAN"=dword:00000001
"ISO14230"=dword:00000001
"ISO15765"=dword:00000001
"ISO9141"=dword:00000001
"J1850PWM"=dword:00000001
"J1850VPW"=dword:00000001
"SCI_A_ENGINE"=dword:00000001
"SCI_A_TRANS"=dword:00000001
"SCI_B_ENGINE"=dword:00000001
"SCI_B_TRANS"=dword:00000001
"SWCAN_ISO15765_PS"=dword:00000001
"SWCAN_PS\"=dword"=dword:00000001
"GM_UART_PS"=dword:00000001
"ProtocolsSupported"="J1850VPW:1, J1850PWM:1, CAN:1, ISO9141:1, ISO14230:1, ISO15765:1, SCI_A_ENGINE:1, SCI_A_TRANS:1, SCI_B_ENGINE:1, SCI_B_TRANS:1, SWCAN_ISO15765_PS:1, SWCAN_PS:1, GM_UART_PS:1"
"LoggingDirectory"="C:\\\\Program Files\\\\Flash2Console
You just have to go into regedit and get it to look at your FunctionLibrary and ConfigApplication.
Life is like a box of programmers you never know which one youll need.
i got it working but i have more then one j2534
i have iflash bs and cardone all2flash and i want to use
both in the same conputer not @ the same time but when i want to test one has more capavilities
Only create second key in register.
HKEY_LOCAL_MACHINE\SOFTWARE\PassThruSupport.04.04\ Device1
HKEY_LOCAL_MACHINE\SOFTWARE\PassThruSupport.04.04\ Device2
Toolbox show you more devices and you select which one you want to use.
Here are toolbox2 for snapon PTP II.
Maybe others can use it.
MEGAUPLOAD - The leading online storage and file delivery service
Anyone get J2534 Toolbox to work with Hotwire as a pass-thru? It's makin me nutz tryin'. Any advice would be greatly appreciated. BTW, There is a FunctionLibrary but ConfigApplication has no value in registry. No mater what I modify, J2534 Toolbox, both old and new versions gives me J2534 driver error message.
Roadwarrior
Works great. Thanks for the instructions.
Used it with SPX MVCI worked like a charm. Needed to replace a PCM in a Dodge Neon with used and could not write the VIN because it already had a valid VIN. The Toolbox software includes a VIN wipe tool and SKIM reset tool. Thanks for the tip, my customer was very happy.
I have a Toyota Mongoose that i use with my Techstream,any one know how to configure it to work with J2534 tool box.
Hi, i have toyota mongoose drewtech (oem) and it work well with j2534 toolbox, just choose interface when open program and done,mongoose not support all non can vehicule like chrysler 2000 to 2007 non can,i try for skim reset in pcm for intrepid without skim module on steering column and pcm come of other car with skim in pcm when i try to connect with pcm error protocole occured, the best it was mongoose chrysler but i not have, or cardaq+,snapon passthru pro or bosch j2534 made by drewtech,bye.
Hi:
I need to use my avdi with the toolbox but i cann't see the device on the list. Can you help me to register it please?
Thank you
BR
