Page 4 of 5 FirstFirst 12345 LastLast
Results 46 to 60 of 67
  1. #46
    alex_r_2001's Avatar
    New Jersey ,, USA
    Any one able to get Autel Maxi Flash to work with toolbox3 or does anyone have a link for toolbox2
  2. #47
    Sep 2018
    can you please tell me how ro make it work with gm mdi i seen a few ways but i think i need to know exactly what files for it to look for. thanks. ok update for somevreason a few files were missing but now i get cant connect to server or device isnt powered on what do people put for device id mine or that 0000259 sny uelp would be great..
  3. #48
    Jun 2017
    US
    Have a China Mini-VCI firmware version 2.0.4 and wondered if I could get this to work with J2534 Toolbox 2. At first was having a hell of a time getting the registry to edit but realized I was on 64bit and the entry to edit is in wow6432node. Then I installed the mongoose driver and it showed up but wasn't doing anything with the MINI-VCI yet. After reading around I found you have to get the MINI-VCI msi driver and extract the installer. It will have a file called MVCI32.dll and this is the file you point to for the registry entry 'Functionlibrary' and then to the firmware update tool for 'ConfigApplication'.
    Now my Mini-VCI cable's led is blinking when I try to pull Crysler Vin under Read Part number! Also it blinks in different patterns for Ford Part Number read. Don't have a dodge here but will try at work tomorrow on my buddies Ram, if he lets me. If that works I'll see if the good stuff, SKIM Reset and ECU reset work on something in a junk yard. I'll be very surprised if it works but worth a shot.
    Edit: Someone else apparently got it working with this method of editing the registry as well.
    https://translate.google.com/transla...ml&prev=search
    Link to download Toolbox 2.0 and Mongoose driver
    http://sigmabit.eu/mongoose-iso-can
    Edit 2: Didn't work on my buddies Ram unfortunately. Maybe I'll try a $150 Multi Diag from China if I don't find something cheaper to try.
  4. #49
    Nov 2015
    Default works well thanks.......
    works awesome tried today with maxisys pro vci seems good.......
    Quote Originally Posted by xbobcz View Post
    I tested J2534Toolbox today. It works with any J2534 device, but it is necessary make small changes in windows registers.
    If you have J2534 from other company, selection of J2534 devices will be empty.
    You have to modify windows registers, that your device is CarDaq and then you can select this device and it works.
    Insert into register:
    [HKEY_LOCAL_MACHINE\SOFTWARE\PassThruSupport.04.04\Drew Technologies Inc. - CarDAQ PLUS]
    "Vendor"="Drew Technologies Inc."
     "Name"="CarDAQ PLUS"
     "ConfigApplication"="CDPLSConfig.EXE"
     "CAN"=dword:00000001
     "ISO15765"=dword:00000001
     "J1850VPW"=dword:00000001
     "J1850PWM"=dword:00000001
     "FunctionLibrary"="C:\\WINDOWS\\SYSTEM32\\CDPLS432.DLL"
    Modify Values according your original device. Leave Vendor and Name untouched. FunctionLibrary value is most important.
  5. #50
    Feb 2017
    :aplausos:buenos dias amigo tengo un vcm 2 quiero utilisarlo con el j2534 d chrsyler q registro devo insertar para q c conecte el vcm2
  6. #51
    Mar 2019
    Does anybody know how to get this working with either a ford VCM2 or if it will work with one of the FVDI V2018 as all I get is a blank drop down box when I open it up.
    Below is what my registry entries look like and help is greatly appreciated especially if I can get it to work with the FVDI V2018 but I don't think thats a passthru device if I am correct.
    Ignore this post as was having a mind blank moment about the Ford VCM and unless somebody says different I have figured out that the FVDI V2018 isnt a passthru device.
  7. #52
    Dec 2010
    UK
    Does someone have a link to older version of toolbox which isnt asking for internet activation?
    Would like Nissan functionality.
    Cheers!
  8. #53
    death9891's Avatar
    E.U.
    Hello how to install J2534 ToolBox software
    I have installed but no data from Drew Technologies Inc. in the registry
    please info how to install?
  9. #54
    death9891's Avatar
    E.U.
    Ok i have,
    and some info to install J2534 ToolBox software + Tech2Win
    I installed Tech2Win Driver for Drew Technologies devices.
    but no luck
  10. #55
    Jul 2012
    Anyone tried with tactrix?
  11. #56
    Malaysia
    Yes. Did it can modify to use with open port 2.0?
  12. #57
    Jan 2019
    Somewhere between Continents
    hello guys.
    Nice post and info...I´m trying to setup an original Tactrix OpenPort 2.0 with J2534Toolbox but i can seem to find how to make this work...
    I was able to change registry so that the device is detected but when i try to do anything it just closes the software...
    This is the "code" i´m using for a Win7 x64 machine:
    Windows Registry Editor Version 5.00
    [HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\PassThruSupport.04.04\Drew Technologies Inc. - CarDAQ PLUS]
    "ConfigApplication"=""
    "DeviceId"=dword:00000000
    "ISO9141"=dword:00000001
    "ISO9141_CH1"=dword:00000001
    "ISO9141_CH2"=dword:00000001
    "ISO9141_CH3"=dword:00000001
    "ISO14230"=dword:00000001
    "ISO14230_CH1"=dword:00000001
    "ISO14230_CH2"=dword:00000001
    "ISO14230_CH3"=dword:00000001
    "J1850PWM"=dword:00000000
    "J1850VPW"=dword:00000000
    "FunctionLibrary"="C:\\Windows\\SysWOW64\\op20pt32.dll"
    Can anyone help me out to make this work?
    Just Consider helping Freely like I want to do...
    Thanks and Rep are Always Welcome...
  13. #58
    vcm2 is possible to use with pcm/ktm bench ?
  14. #59
    Jun 2014
    ankara-turkei
    need .reg file for avdi original passthru,I can pay toolbox2 and ifpossible toolbox3 too..
  15. The Following User Says Thank You to caliskan71 For This Useful Post:
    pinotec (4th November, 2020)
  16. #60
    Jul 2012
    Quote Originally Posted by boxsport View Post
    hello guys.
    [HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\PassThruSupport.04.04\Tactrix Inc. - OpenPort 2.0 J2534 ISO/CAN/VPW/PWM]
    "Name"="OpenPort 2.0 J2534 ISO/CAN/VPW/PWM"
    "Vendor"="Tactrix Inc."
  17. The Following User Says Thank You to aef For This Useful Post:
    boxsport (30th September, 2020)
