here is the pic i used
found it in a zip file posted on these forums by someone else
i wired the adapter like this and still no go
autoelite (27th April, 2019)
Good on you mate,
it seems lawn is greener over the ditch for Kiwis, you must be doing well and decent customer population so afford all genuine stuff.
As said TPX1/2/3 are great and can be used on many machines, like CR2 ( highly recommeded) and ZB, not sure about AD900. all my TPX1/2/3 stuff were all from autokeys, no problem experienced.
slideshow for the toyota landcruiser, open the ecu locate the eeprom post your dump we will give you the virgin rar.
or try this rar on the eeprom ,virgin rar attached
n599fbm (16th July, 2015)
i used the t300 and reprogrammed a key that was from another landcruiser
worked ok
i wire up conversions so basically we wired up a 2004 landcrusier motor into an older 1997 ladncruiser and the wrekcing yard supplied a missmatched set
so i bought the t300 and figured out how to prog anpother key with no master keys
car starts good now
now im just going thru this site to learn more on how these things work
maybe one day ill learn about reading the immob ecu dumps
but thanks to all for the info
please help me.
i need file dump orginal SMART COMPUTER ASSY Toyota 2010.
Part No.89990-33151.
please help me.
i need file dump orginal immobiliser Toyota 2010.
Part No.89784-33011.
Hi mate, what's the year of your Camry?
T300 can only support cars before 2007, if your car after 2007, you can't blame it for not working.
camry is 2003
i got it to work eventaully
usual wiring problem
hi
i have file dump orginal immobiliser Toyota 2009.
Part No:
ID Code Box : 89784-60060
G'day from FNQ. Do you know if the T300 (V17.8) will read the PIN from the ECU or ICU on a Holden Jackaroo 3.0L 4JX1 (1998-2004)?
Will the T300 (V17.8) allow me to reset PIN and then write a new PIN to the Immobilizer?
