Page 4 of 39 FirstFirst 12345678914 ... LastLast
Results 46 to 60 of 572
  1. #46
    how come no setanta on sky uk
  2. #47
    Aug 2010
    You will find Setanta under Sky Eire mate.....
    DM800 HD Running Dream Elite BH1.33 in flash, Gibertini 1 metre dish ,DarkGold 0.1 Single lnb,Super DARK MOTOR ( Metal Gear ) Sony Bravia KDL40W4000 12 month DigitAlb card ...
  3. #48
    Jul 2011
    Quote Originally Posted by 00360362878 View Post
    I assume you have downloaded dreamset. Open the file, as you say you will see plenty of files, open the dreamset application, as I say the one that has the dish icon. Click on open top left, you will then need to find the settings file you downloaded from catseye. Load that and it will open the settings into, set bouquets. You then need to edit your regional services to your needs ie delete the ones that you do not want to use. when you have don this you need to save the changes and then ftp the new settings to you box. There are various guides for this, have a look at the guide for dreambox edit it's very similar.
    Sorry marcus.. Have you not set your 800se up yet ie image etc?
    hi
    i had my image set up for me IVSC
  4. #49
    DK Veteran catseye's Avatar
    Nov 2008
    England
    Default Catseye E2 Settings file 75 East-58 West 11.11.2011
    Includes most recent updates from KOS & more...
    7 west
    Many changes on this satellite which are still on going at present
    28.2 East
    Many changes to pids & sids with some services now moved to Astra 1N
    42 East
    More new HD channels added to D Smart package
    16 East
    Eutelsat W3C came into operation this week meaning almost all of the channels have altered in some form on this satellite
    **Please note this new satellite is broadcast from 16.0 East so apart from moving your dish slightly from 15.8 east**
    **You will need to amend your satellite configuration settings otherwise the new settings may appear 'greyed out'**
    Enjoy
  5. #50
    Hi trying to load these settings via dreamboxedit and getting this error -
    Connected.
    Dreambox response: Login successful.
    ** Getting directory list /etc/enigma2/* **
    Starting FTP transfer
    Transfer complete
    ** Sending file "/etc/enigma2/lamedb" **
    Transfer aborted
    Error sending file "lamedb" to the Dreambox.
    Disconnecting.
    Disconnected.
    I've loaded other updates in the past the same way without problems? nothings changed in dreamboxedit settings it says my ip and password are correct?
    any ideas?
  6. #51
    V.I.P. Member andy91's Avatar
    Aug 2010
    East Midlands
    Quote Originally Posted by beats2006 View Post
    Connected.
    Transfer complete
    Transfer aborted
    Disconnecting.
    Disconnected.
    any ideas?
    When you select Catseyes bouquets make sure you double click with mouse so you see the files in the directory,they will look greyed out,thats your problem.
    You're not actually loading the bouquets before you send them.
    Another thing in Options click on Enigma 2 settings and save.
    Andy.
  7. #52
    Quote Originally Posted by andy91 View Post
    Andy.
    Yeah I was selecting the folder fully and I've tried clicking enigma 2 settings again and saving and still no joy?
  8. #53
    Aug 2010
    East Midlands
    Have you made sure you have put the correct ip address in?
    Could always try Dreamset instead of Dreambox Edit,
    Andy.
  9. #54
    Andy.
    Yeah IP and password etc are all working and correct, been having lots of other problems with tuner etc so gona try another image and hoepfully that'll sort it. starting to wish Id bought the box from the UK now instead of China.
  10. #55
    ReFlash solved the bouqet loading problem but still getting tune failed every 5 mins think this box is gona finish up in the bin
  11. #56
    Aug 2010
    East Midlands
    Not sure what box you have but i would go with a few images till you get it right and dont download to many extras as it sounds they might be the problem.
    Who did you order from and is it the Dreambox 800Se.
    Everytime i read a post it seems like they are problematic.
    Andy.
  12. #57
    Andy.
    Yeah its the DM800SE its been a nitemare from start to finish, worked perfectly for a few weeks but thats it, Got it from China a guy called tony xuan on aliexpress cost about ?156
  13. #58
    Does anyone have a problem with Premier Sports?
    It decodes ok with my Official but even though that is working there is NO picture or sound yet I know there is a programme running there are no error messages just a blck blank screen.
    Also are we not short of a BBC Stream or 2?
  14. #59
    V.I.P. Member SGTFlipFlop's Avatar
    Scotland
    Quote Originally Posted by Coach View Post
    Premier Sports needs Oscam to decrypt that channel same as Pick TV
  15. #60
    Thanks for that, any reason why?
    Also am I right about missing BBC streams?
    cheers
