Results 1 to 13 of 13
    May 2010
    Default renault edc16c3 problem
    Hi guys, have a renault megane 2003 edc16c3 which following a bad read with mpps v10 has left the ecu with no injector coding. All injectors show a coding of A. I have tried to manually program the injector codes with clip but it fails stating internal electrical failure.
    The car starts and runs but only to 1500rpm, MPPS read the id ok but failed almost straight away when attempting a normal read instructing me to contact amt, my mpps is a clone. Can anyone suggest a fix please?
    Many thanks in advance.
    Dec 2010
    UK
    BDM ori data and start again.
    MPPS doesnt recode config data such as inj coding on Renault or PSA, so best to use tool that does or BDM.
    Dec 2010
    You must code injectors with proper diagnostic tools like renault can clip without any problem, I did it few times!
    Feb 2010
    you can find the codes written on each injector, make sure you count injector 1 from the belt
    Dec 2010
    UK
    Cyl 1 is flywheel end
    furnata's Avatar
    Feb 2010
    Bulgaria
    And the injectors code is writen in e2prom -8pin soic
    i_shot_the_sheriff's Avatar
    Nov 2008
    ARe the injectors in the 95160 8pin? If yes is there a way to add them manually (with hex editor?)
    Member mbtuning's Avatar
    Apr 2012
    just use renault can clip ... in most of cases works great.
    Magpro2 / MagBDM / X17 / New Genius / Powergate Full / MPPS / FGTech / WINOls 2.20 and much more ...
    Chiptuning / DPF OFF / EGR OFF / Hot start - solutions ...
    MBTUNING.RO
    Nov 2008
    It is weird that can clip won't program the injectors for this ecu!!!! I've tried another ecu with different numbers and it worked,,, but not with this one!
    That why i'm searching for a way to add them manually via the eprom
    ecutuners's Avatar
    Apr 2011
    United Kingdom
    The codes are inside eeprom in hex format,read eeprom of the spare ecu and then program some injectors to it, read eeprom again you will see where they are stored
    Kess v2 FW 5.017 full unlimited token - Ktag 7.020 full unlimited token
    ALL EDC17/MED17 EEPROM CHECKSUM + VAG IMMO OFF BY EEPROM - NO SAFE
    EDC16/17 POPCORN - ME7/7.5 ANTI LAG - LAUNCH ALS/NLS
    DPF EGR DTC SCR, Custom Tuning, Damos Translation, FRF / SGO Files
    Professional Engine Software Development
  11. #11
    Nov 2008
    THe problem is that the Injector codes are not in plain text (in the hex format)....but are encrypted!!!
  12. #12
    koolstuff's Avatar
    Nov 2015
    Dakar (Senegal)
    i have similar problem with renault master2 and my clip can is bricked
  13. #13
    Aivis3's Avatar
    Sep 2016
    Latvia
    Easy with Galletto4. Need to read injector file, save, repair it and upload to ecu.
