Page 69 of 141 FirstFirst ... 1959646566676869707172737479119 ... LastLast
Results 1,021 to 1,035 of 2114
  1. #1021
    bidu20's Avatar
    Jun 2016
    Quote Originally Posted by alclot View Post
    Hi mates,
    I have this dash from opel antara 2007. Can I have power up here?
    Thanks in advance
    1 Kl. 15
    2 Kl. 30
    3
    4
    5
    6 Aussentemperatur
    7 Aussentemperetur
    8 Waschwasserstand
    9
    10
    11
    12
    13 Kl. 31
    14 LIN-Bus
    15
    16 Bremsflüssigkeits- warnung
    what is the problem of this dash? Maybe i can help:-)
  2. The Following 5 Users Say Thank You to bidu20 For This Useful Post:
    alclot (14th August, 2018), gsmflasch (10th January, 2019), misamix (17th January, 2022), silo1992 (10th March, 2023), Stelaras26 (29th March, 2023)
  3. #1022
    bidu20's Avatar
    Jun 2016
    Quote Originally Posted by llanesluna View Post
    Kia Sorento 2012, cannot find power up for this cluster. Any help pls?
    Stecker A
    (12 Pin)
    2 Motorkontroll- lampe
    3 Öldruck
    4
    5 Immobilizer
    6
    7 Kl. 30
    8 Kl. 15
    9
    10
    11
    12
    Stecker B
    (16 Pin)
    2 Kl. 31
    3 Rheostat
    Öffnen-taste
    4 4-Impuls Ausgang
    5
    6
    7 Summer Eingang
    8
    9
    10
    11
    12
    13 Eingang OAT
    14 Rheostat Raste Ausgang
    15 Wasser- abschneider
    16 Kl. 31
    Stecker C
    (12 Pin)
    1 C-CAN Low
    2 C-CAN High
    3
    4
    5 Rheostat Schliessen-taste
    6 Kl. 58 +
    7 Generator Eingang
    8 Waschanlage niedrige Stufe
    9 SRS
    10 SRS
    11 B-CAN High
    12 B-CAN Low
    Stecker D
    1 Rheostat Ausgang
    3 Rheostat Masse
    4
  4. The Following 2 Users Say Thank You to bidu20 For This Useful Post:
    alclot (14th August, 2018), llanesluna (13th August, 2018)
  5. #1023
    bidu20's Avatar
    Jun 2016
    Quote Originally Posted by Norveg View Post
    Can Bus simulator for dashboard. Whitch tools is a usable?
    Tapatalkkal küldve az én WAS-LX1 eszközömről
    I use this:
    https://www.peak-system.com/PCAN-USB.199.0.html
    greets
  6. The Following User Says Thank You to bidu20 For This Useful Post:
    Norveg (13th August, 2018)
  7. #1024
    Quote Originally Posted by bidu20 View Post
    Thanks for the link so is it easy to use ?
    Also what software are you using ?
  8. #1025
    bidu20's Avatar
    Jun 2016
    Quote Originally Posted by rastus86 View Post
    i use this Software:
    https://www.peak-system.com/PCAN-View.242.0.html
    https://www.peak-system.com/PCAN-Trace.247.0.html
    yes its easy to use. with the "View"software you can generate your own messages and with the "Trace" you can recording and play the messages.
  9. The Following User Says Thank You to bidu20 For This Useful Post:
    alclot (20th August, 2018)
  10. #1026
    Oct 2015
    So in most cases, you need to record CAN signal from car.
  11. #1027
    I am very interested in this
    I have been looking at this type of stuff for awhile
  12. #1028
    May 2016
    Czech
    Hi Everyone
    I need power up for Yamaha TDM 900
  13. #1029
    Jun 2018
    Hi Everyone
    I need power up for Toyota Corolla 2005
  14. #1030
    cjawahir's Avatar
    T&T
    Quote Originally Posted by banglanetdhk View Post
    Hi Everyone
    hello bro here is the pinout u need
    cj
  15. #1031
    Jun 2018
    Not working Bro
  16. #1032
    cjawahir's Avatar
    T&T
    Not working Bro
    strange , it working for me i have that cluster , maybe your is damage or really diffrent
    cj
  17. #1033
    Jan 2018
    Hi guys.
    GMC Yukon Denali 2008
    I cannot find the power up pinout, and the can pin. Does anyone has this info?
    I got this pdf, but not clear for me those pins.
  18. #1034
    Plcautoparts's Avatar
    Mar 2013
    Hi guys.
    Do you have picture of connector? 1 and 5 I think positive, 13 GND. But need to see connector then I might be able to check the can
    pins for power above are correct and Pin 6 Low Speed GMLAN Serial Data.
    Sent from my SM-G955U using Tapatalk
    A simple thanks would do, If it didn't work at least I tried.
  19. The Following User Says Thank You to Plcautoparts For This Useful Post:
    llanesluna (25th August, 2018)
  20. #1035
    Jan 2018
    Quote Originally Posted by Plcautoparts View Post
    Here’s. Thanks in advance.
