Power Up Collection - Page 70
Page 70 of 141 FirstFirst ... 2060656667686970717273747580120 ... LastLast
Results 1,036 to 1,050 of 2109
  1. #1036
    Plcautoparts's Avatar
    Mar 2013
    check post above , test and report, good luck
    A simple thanks would do, If it didn't work at least I tried.
  2. The Following User Says Thank You to Plcautoparts For This Useful Post:
    llanesluna (25th August, 2018)
  3. #1037
    Jan 2018
    Quote Originally Posted by Plcautoparts View Post
    Have any idea which is the data communication pins?
  4. #1038
    Mar 2013
    Should be Pin 6 Serial Data cluster to pin 1 on DLC Dark Green wire
  5. The Following User Says Thank You to Plcautoparts For This Useful Post:
  6. #1039
    Aug 2018
    I want to know about the Brazilian Celtic as I have
    Quiero saber sobre el celta brasileņo como lo tengo
  7. #1040
    Jan 2018
    Worked! Thanks
  8. #1041
    Jan 2018
    Do you have picture of connector? 1 and 5 I think positive, 13 GND. But need to see connector then I might be able to check the can
    pins for power above are correct and Pin 6 Low Speed GMLAN Serial Data.
    Sent from my SM-G955U using Tapatalk
    Im a little bit confusing about the data line. I tried the KLine and the PIN1 from my tool. None work.
    Which one should I use? Im using a CAN emulator.
  9. #1042
    alclot's Avatar
    Melee Island
    Hi mates,
    I have this dash from Opel Zafira year 2002. Can anyone help with power up and comunication lines?
    Thanks in advance
  10. #1043
    bidu20's Avatar
    Jun 2016
    Quote Originally Posted by alclot View Post
    Hi mates,
    Thanks in advance
    Stecker weiss
    (36 Pin)
    1 Nebelschlussleuchte
    2 Kl. 31
    3
    4 Kl. 30
    5 Automat
    6 Automat Sport
    7 Blinker Anhänger
    8 Blinker rechts
    9 Blinker links
    10 ABS
    11 Nebellampen
    12 Sicherheitsgurte
    13 Traction Control
    14
    15
    16 Alternator D+ (Kl.61)
    17 Fernlicht
    18 Airbag
    19 Diagnose
    20 Drehzahl 33 Hz = 1000 đ/min
    21
    22 Kl. 15
    23
    24 Kl. 31
    25 Tank 250Ω = leer
    60Ω = 50 Lt
    26
    27 Geschwindigkeits-
    signal
    WIZ = 15300
    28 Kühlwassertemp. 100 Hz o. C. = Zeigerbreite vor 90°
    29
    30 Glühzeitlampe
    31 Klimaanlage
    32
    33 Motoröldruck
    34 Motorlampe
    35 Bremssystem
    36 Standlicht
    here my friend
  11. The Following User Says Thank You to bidu20 For This Useful Post:
    alclot (28th August, 2018)
  12. #1044
    alclot's Avatar
    Melee Island
    Hi again mates,
    I have dash from Ford Mondeo year 2007. May I have power up here please?
    Thanks in advance
  13. #1045
    bidu20's Avatar
    Jun 2016
    Hi again mates,
    Thanks in advance
    Stecker
    4 Kl. 15
    5
    6 Kl. 31
    7
    8
    9
    10
    11
    12
    13
    14
    15
    16
    Stecker
    17
    18
    19
    20
    21
    22 CAN Low
    23 CAN High
    24
    25
    26
    27
    28
    29
    30
    31
    32 Kl. 30
    whats the problem with your dash?
    greets
  14. The Following User Says Thank You to bidu20 For This Useful Post:
    alclot (30th August, 2018)
  15. #1046
    Feb 2017
    Madrid Spain
    can someone tell me how to turn on this bmw s1000rr motorcycle board 2017-2018 at the bank? in the forum there is pinout of the old bicycle but it does not light with this: S
  16. #1047
    bidu20's Avatar
    Jun 2016
    Hi again mates,
    Thanks in advance
    here is CAN for power up..pass in pm :-)
  17. The Following 2 Users Say Thank You to bidu20 For This Useful Post:
    alclot (31st August, 2018), ptikkala (24th May, 2020)
  18. #1048
    Jan 2018
    Nissan 370Z 2012 any help with this one?
  19. #1049
    Jun 2018
    Virgin Islands
    Default Power Up Collection
    What would you be offering for said spare power supply?I have two here, one working xbox ATM but am hard pressed to want to sell.
  20. #1050
    Meat-Head's Avatar
    Quote Originally Posted by bidu20 View Post
    What a crettin passwording stuff, do you password your order at macdonalds?
