Page 103 of 141 FirstFirst ... 353939899100101102103104105106107108113 ... LastLast
Results 1,531 to 1,545 of 2114
  1. #1531
    rtbdiagnostic's Avatar
    May 2015
    My Tool Room
    Need power up on bench for this 2008 BMW R1200GS cluster please
    'If I helped, please click Thanks +Reputation.. !'
  2. #1532
    jjservice's Avatar
    Sep 2016
    VIENA,AUSTRIA
    Quote Originally Posted by boxa76 View Post
    Attachment 730631Attachment 7306322014 ford ranger
    Need power ON pin out please
    Bro eve if you can power up this dash gauge of a Ford/Mazda you canot able to view the mile age,, it will not show unless it is connected into the car.... good luck
    Sent from my SM-J710GN using Tapatalk
    if you think i helped youkindly press REP+THANKS button
  3. #1533
    neksus's Avatar
    Jun 2013
    Does anyone have power up for for DASH, Kawasaki GTR 1400 2012
    Best regards
    PRESS THANK + REPUTATION
  4. #1534
    McDowell's Avatar
    Feb 2019
    Zamunda
    HONDA LEGEND (KB1/2)3.5 V6 CAT POWER UP
    Thanks a lot in advance
  5. #1535
    Jun 2020
    Hello, dose any one can guide me how do I power up the cluster, which is the positive and negative, thanks you,
    Toyota Corolla 1.4,
    Cluster Seimen Vdo, AG
  6. #1536
    neksus's Avatar
    Jun 2013
    Quote Originally Posted by stzmotors View Post
    Toyota Corolla 1.4,
    Here......
  7. The Following 5 Users Say Thank You to neksus For This Useful Post:
    dustooff (3rd February, 2021), mcd76 (12th August, 2020), rtbdiagnostic (10th August, 2020), skens (6th August, 2020), stzmotors (7th August, 2020)
  8. #1537
    Port Elizabeth
    Default Ford Ranger 2013 powerup connection
    Hi I need power up connection for ford ranger 2013 t6 with 24c16 chip on bench
    Cheers
    Shane
  9. #1538
    May 2015
    My Tool Room
    Cheers
    Shane
    Quote Originally Posted by jjservice View Post
    Seems mileage only visible when connected to vehicle itself
  10. The Following User Says Thank You to rtbdiagnostic For This Useful Post:
    shanektm450 (17th August, 2020)
  11. #1539
    Port Elizabeth
    Hi thanks I do understand I have a bcm on bench just need power up of the cluster then I can share working solution for mileage on bench
    Cheers
    Shane
  12. The Following User Says Thank You to shanektm450 For This Useful Post:
    rtbdiagnostic (17th August, 2020)
  13. #1540
    Port Elizabeth
    Ok got it sorted :
    pin 18 - ign
    pin 17 - battery
    pin 11 - negative
    pin 6 - can to obd plug 3
    pin 7 - can to obd plug 11
    If you got BCM on bench then you need to connect pin 6 and 7 to bcm and splice in to can to obd plug , I manged to do mileage on bench with cluster only , to test to see mileage is to unplug cluster and plug back in again with out turning on ign then you see mileage
    Cheers
    Shane
  14. The Following 4 Users Say Thank You to shanektm450 For This Useful Post:
    dustooff (3rd February, 2021), MileageAudit5 (4th January, 2023), rtbdiagnostic (20th August, 2020), Tyson500 (11th November, 2021)
  15. #1541
    HI.
    Any have power up for this yamaha n-max 2016?
    Thanks.
  16. #1542
    Mar 2016
    Argentina
    Quote Originally Posted by serviclau View Post
    HI.
    Thanks.
    hi clau
    page 101
  17. The Following User Says Thank You to chris781 For This Useful Post:
    julo45 (28th August, 2020)
  18. #1543
    2018 KIA sportage c/w 25c160
    need to check mileage on bench
    2018 kia sportage with 25c160 eep .
    1 black 40pin connector
    can anyone help with power ups ?
    please add rep & thanks if my post was helpful
  19. #1544
    Sep 2018
    USA
    Default 18 sportage power up
    Quote Originally Posted by sparkle View Post
    this should work just do the one negative and one positive.
  20. The Following User Says Thank You to MileageAudit5 For This Useful Post:
    popov (8th June, 2022)
  21. #1545
    May 2015
    My Tool Room
    Anybody can assist with power up on bench for this 2017 Isuzu DMax with RH66 - 93c66 chip it has a black connector
