Page 120 of 141 FirstFirst ... 2070110115116117118119120121122123124125130 ... LastLast
Results 1,786 to 1,800 of 2114
  1. #1786
    soukehal's Avatar
    Default Dacia logan 2012
    Bonjour et bon travail à tous j'ai besoin de brochage pour
    93c56 dash sagem Dacia logan 2012 Power up
  2. #1787
    jjservice's Avatar
    Sep 2016
    VIENA,AUSTRIA
    Here is another contribution
    subaru impreza
    if you think i helped youkindly press REP+THANKS button
  3. The Following User Says Thank You to jjservice For This Useful Post:
    tabasco1 (6th November, 2021)
  4. #1788
    soukehal's Avatar
    it is resolved.
    7 "Ground"
    9 "+" Battery
    10 Power supply after contactor
    CONNECTOR 24 pins black
    Pin / Assignment
    1 Control of the electronic engine immobilizer warning light
    2 Emergency coolant temperature warning light
    3 Not used
    4 Emission reduction system indicator light
    5 Rear fog light warning light
    6 Fog light warning light
    7 "Ground"
    8 Signal - "Fuel level sensor
    9 "+" Battery
    11 Supply voltage "+" Side lights
    12 Coolant temperature sensor "+" signal
    13 Battery charge indicator
    14 Oil pressure warning light
    15 Indicator light
    16 Parking brake and brake fluid level warning light
    17 Heated rear window warning light
    18 High beam indicator light
    19 Low beam indicator light
    20 Airbag fault warning light
    21 Tachometer
    signal 22 Vehicle movement speed signal
    23 Button for viewing information on the on-board computer screen
    24 Fuel level sensor "+" signal
    CONNECTOR (24 pins gray) (not available as standard)
    Pins / Assignment
    1 Not used
    2 Not used
    3 Passenger airbag locking warning light
    4 Not used
    5 Not used
    6 Not used
    7 Not used
    8 Not used
    9 Not used
    10 Not used used
    11 Not used
    12 Indicator light for open doors
    13 "Ground" (without ABS configuration), Electronic brake force distribution warning light (with ABS configuration)
    14 Not used
    15 Not used
    16 Earth (without ABS configuration), ABS malfunction indicator light (complete with ABS)
    17 Not used
    18 Not used
    19 Fuel consumption signal
    20 Not used
    21 Not used
    22 Not used
    23 Not used
    24 Not used
  5. The Following User Says Thank You to soukehal For This Useful Post:
    onell77 (17th October, 2021)
  6. #1789
    jjservice's Avatar
    Sep 2016
    VIENA,AUSTRIA
    Quote Originally Posted by jjservice View Post
    Anyone has a POWER UP PIN OUT on bench for this BMW S1000RR?
    thanks in Advance
    Sent from my SM-J710GN using Tapatalk
    I figure out the suply voltage...
    Enjoy....
  7. The Following 3 Users Say Thank You to jjservice For This Useful Post:
    drgelo (19th October, 2023), onell77 (17th October, 2021), StormBY (22nd July, 2023)
  8. #1790
    tfourk's Avatar
    Jan 2016
    Fort Lauderdale, FL
    Sorry to reask. Need the 2005 Honda Element. The previous sourced page is no longer available thanks.
  9. #1791
    Dec 2011
    Thanks for your useful post!
  10. #1792
    Oct 2021
    Hi all
    Please pinout speedometer:
    Mazda 3 2005 Cluster complete
  11. #1793
    Aug 2011
    Corsa E ... need 3-4s to power up
  12. #1794
    jjservice's Avatar
    Sep 2016
    VIENA,AUSTRIA
    Quote Originally Posted by onell77 View Post
    Hi all
    here you go
    Attachment 841610
  13. The Following 4 Users Say Thank You to jjservice For This Useful Post:
    boxsport (20th October, 2021), onell77 (18th October, 2021), Silver740 (30th October, 2021), tabasco1 (6th November, 2021)
  14. #1795
    May 2021
    I am looking for pinout for this Porsche Boxster cluster
  15. #1796
    KUM900's Avatar
    Feb 2019
    Jeep Liberty 2005
  16. #1797
    Sweden
    Please pinout speedometer:Skoda Octavia 2020 WIN_20211101_13_15_59_Pro.jpgWIN_20211101_13_16_18_Pro.jpg
    Power Up
  17. #1798
    Feb 2021
    Looking power up pins seat exeo 2011
  18. #1799
    skens's Avatar
    Zagreb,Croatia
    hi
    maybe help you!!
    virtual dash vw
    regards
    Please dear members push the button thanks and reputation button(stars)
    do you need help? fill it in !!!
    Model:
    Motor capacity:
    Diesel/Gasoline:
    Production year:
    ECU type and number:
    Memories :
    https://www.digital-kaos.co.uk/forum...63#post1660863
  19. The Following 2 Users Say Thank You to skens For This Useful Post:
    rtbdiagnostic (4th November, 2021), tabasco1 (6th November, 2021)
  20. #1800
    Feb 2021
    Seat exeo 2011 green connector pin 2,3 +12v pin 18 gnd
  21. The Following User Says Thank You to solder king For This Useful Post:
    dashradio (7th November, 2021)
