Page 59 of 141 FirstFirst ... 949545556575859606162636469109 ... LastLast
Results 871 to 885 of 2111
  1. #871
    hass42's Avatar
    Aug 2012
    USA
    2000 VW Beetle Dash /
    xc525099cpv chip read like 68hc9s12d60 Beetle cluster connection
  2. The Following 6 Users Say Thank You to hass42 For This Useful Post:
    capi (26th September, 2020), cjawahir (15th January, 2020), keysmith (24th March, 2021), pokusmaster (14th November, 2022), rtbdiagnostic (28th February, 2018), teo21 (26th February, 2018)
  3. #872
    Feb 2010
    needed the connections for dashboard mazda bt 50 2006/2007
  4. #873
    May 2017
    Hi guys! I have a VDO Golf 6 cluster and I want tu read it with VCDS . I connected pins 31 32 to +12v ,pin 16 to ground and 28 can high, 29 can low (these are the cluster's pins); at the Vag Com obd2 interface I connected pin 4 to gnd , pin 16 to +12v and pin 6 can high, pin 14 can low (connected with pin 28 and pin 29 from cluster) but I can't read them . Is there anything else I should connect? Thank you in advance and sorry for the off topic !
  5. #874
    Dec 2015
    Quote Originally Posted by fcarocha View Post
    Try this
  6. The Following 2 Users Say Thank You to Rediah For This Useful Post:
    capi (26th September, 2020), fcarocha (11th March, 2018)
  7. #875
    Jul 2016
    USA
    looking for 2004 ford freestyle pinout / power up
  8. #876
    drugowaz's Avatar
    Mar 2015
    Lithuania
    maybe anyone has gathered collection in one link or rar? and could share ,can to pm too.
    Renault ECU tool / IO terminal / A.S.W
  9. #877
    Aug 2011
    Toyota Yaris 2004
    regards
  10. The Following 5 Users Say Thank You to pipina For This Useful Post:
    capi (26th September, 2020), JotaB (3rd October, 2022), pedrod2005 (20th July, 2020), vasa (10th March, 2018), _estima_ (28th July, 2018)
  11. #878
    jjservice's Avatar
    Sep 2016
    VIENA,AUSTRIA
    Anyone has a connection to power up this ISUZU DMAX
    Sent from my SM-J710GN using Tapatalk
    if you think i helped youkindly press REP+THANKS button
  12. #879
    cjawahir's Avatar
    Dec 2009
    T&T
    isuzu dmax 2009 check pin 1 is ground and pin 8 is +12VOLTS .
    notice the numbers on the 16 pin connector where its solder to the pcb .
    cj
  13. The Following 2 Users Say Thank You to cjawahir For This Useful Post:
    asystema (17th August, 2021), dashradio (12th March, 2018)
  14. #880
    tfourk's Avatar
    Jan 2016
    Fort Lauderdale, FL
    2013 Kia Soul power up. Pictures of the unit.2018-03-13 11.01.30.jpg 2018-03-13 11.01.11.jpg2018-03-13 11.04.17.jpg Thanks for the help.
  15. #881
    cjawahir's Avatar
    Dec 2009
    T&T
    Quote Originally Posted by tfourk View Post
    remove the cover u will see batt= battery 12 volts , ign = ignition 12 volts , and gnd = ground - trace with dvm to pins .
    cj
  16. The Following 2 Users Say Thank You to cjawahir For This Useful Post:
    Stelaras26 (14th March, 2018), tfourk (3rd October, 2019)
  17. #882
    jjservice's Avatar
    Sep 2016
    VIENA,AUSTRIA
    Quote Originally Posted by mine21 View Post
    heres the Toyota Avanza 2014 bench power up...Attachment 355375
    br,
    mine21
    Hello mate
    Is this the toyota avanza which has a 93c56 nano or normal size??
    Thanks jn advance..
  18. The Following User Says Thank You to jjservice For This Useful Post:
    rtbdiagnostic (15th June, 2021)
  19. #883
    DK Veteran technobox's Avatar
    Apr 2010
    cyprus
    suzuki alto need power up
    never lost anythink only change ...
  20. #884
    Jul 2010
    world
    Anyone has a power up pinout for Fiat Brava 2001 cluster?
  21. #885
    credoline's Avatar
    Србија
    Send picture from back of cluster to see connector. It is cluster with ST ?
    It is this kind ?
