alclot (14th August, 2018), gsmflasch (10th January, 2019), misamix (17th January, 2022), silo1992 (10th March, 2023), Stelaras26 (29th March, 2023)
Stecker A
(12 Pin)
1 2 Motorkontroll- lampe 3 Öldruck 4 5 Immobilizer 6 7 Kl. 30 8 Kl. 15 9 10 11 12
Stecker B
(16 Pin)
1 2 Kl. 31 3 Rheostat
Öffnen-taste4 4-Impuls Ausgang 5 6 7 Summer Eingang 8 9 10 11 12 13 Eingang OAT 14 Rheostat Raste Ausgang 15 Wasser- abschneider 16 Kl. 31
Stecker C
(12 Pin)
1 C-CAN Low 2 C-CAN High 3 4 5 Rheostat Schliessen-taste 6 Kl. 58 + 7 Generator Eingang 8 Waschanlage niedrige Stufe 9 SRS 10 SRS 11 B-CAN High 12 B-CAN Low
Stecker D 1 Rheostat Ausgang 2 3 Rheostat Masse 4
alclot (14th August, 2018), llanesluna (13th August, 2018)
I use this:
https://www.peak-system.com/PCAN-USB.199.0.html
greets
Norveg (13th August, 2018)
i use this Software:
https://www.peak-system.com/PCAN-View.242.0.html
https://www.peak-system.com/PCAN-Trace.247.0.html
yes its easy to use. with the "View"software you can generate your own messages and with the "Trace" you can recording and play the messages.
alclot (20th August, 2018)
So in most cases, you need to record CAN signal from car.
Hi Everyone
I need power up for Yamaha TDM 900
Not working Bro
Hi guys.
GMC Yukon Denali 2008
I cannot find the power up pinout, and the can pin. Does anyone has this info?
I got this pdf, but not clear for me those pins.
A simple thanks would do, If it didn't work at least I tried.
llanesluna (25th August, 2018)
