Page 2 of 12 FirstFirst 1234567 ... LastLast
Results 16 to 30 of 175
  1. #16
    Newbie tradedemon's Avatar
    Oct 2011
    The whole time travel thing is just a dream, and most of us lived it up watching back to the future... I think they covered most things most of us would try...
    and if you still want to explore more, I guess you have your dreams.... anyone here know how to lucid dream or if it's even real ?
  2. #17
    camelgd's Avatar
    Jan 2011
    South Illinois
    Default Time travel
    Just the name "time travel" is a misnomer. Travel implies going from one place to another-time transfer is closer, but still implies movement. It is hard to get past that rate x the time, you end up with distance. Time shift would have to be transdimensional, or better yet, to be in a certain place to see everything at once, eternity in both directions. The closest I have seen to a description of something like that is John in the book of Revelation.
    camelgd
    Kinda makes you want to duct tape your head to hold it together.
  3. #18
    DK Veteran KenshinPT's Avatar
    Mar 2010
    PT
    Hello,
    If time travel exists this means that you can travel to the past and to the future!
    So, if you can travel to the past/future (depending on which referencial we're talking), then time travel already exists at our present time
    For those o didn't understood, if time travel exists, that means that someone from the future can travel to it's past and reach our present! OK?
    I am not saying that it's possible or impossible I just want to confuse you more
    Regards!
    Did it help? Push Thanks below
  4. #19
    V.I.P. Member Dreamer's Avatar
    Apr 2008
    Glasgow area
    ffs r u lot still using primative forums for communication... get a grip and get holographic resonaisance communication... (HRC) jeez
    The Falkirk Wheel. The only rotating boat lift of its kind in the world
  5. #20
    Kalipo's Avatar
    Mar 2008
    Reichstag, Berlin
    Quote Originally Posted by KenshinPT View Post
    Hello,
    Regards!
    I don't understand, How can you travel to the future..
    Scrap that.. I have a machine and decide i want to go to December 2012.. I end up at the correct time and discover that nothing is there except buildings etc.. Would it mean the people in the past are still in the past??
    Surely traveling forward would be pointless because the people you visit would know you have time traveled forward and wouldn't be interested in what you have to say because technically you are from the past and they already know what you are going to say..
  6. #21
    DK Veteran johnboy1974's Avatar
    Dec 2008
    glasgow
    i thought einstien stated that time travel was possible if you exeeded the speed of light.
  7. #22
    DK Veteran RedSpider's Avatar
    Feb 2009
    F**k Off, You Stalker!!!
    Quote Originally Posted by johnboy1974 View Post
    i did thinked that the einstine man did sayeded that you can do time travels if you go at the speed of light.
    he also stated that reaching the speed of light would be impossible as it would require infinite fuel in order to overcome increased mass.
    however, einstein didn't count on the invention of the flux capacitor which only requires a speed of 88mph.
    he also didn't count on sam becket who discovered that time travel was possible simply by doing a few stretches in a bright, smoky chamber
    Syntax Error : Integer Out Of Range
    Hooray For Tits & Fannies
  8. #23
    V.I.P. Member cantona7's Avatar
    Apr 2008
    essex
    88mph and a delorean pre-fitted with a flux capacitor
    and sam beckitt needed a mate called al too !!!!
    ps....~~~~ed if i can remember how to spell delorean
    when the sea gulls follow the trawler,it is because they think sardines will be thrown into the sea
  9. #24
    Feb 2009
    Quote Originally Posted by cantona7 View Post
    he didn't ''need'' al, it's just nice to have a friend along
  10. #25
    Apr 2008
    essex
    so you are saying al was just a tag along on sams coat tails ???
  11. #26
    Feb 2009
    well how much 'help' was he really?
    he actively encouraged sam to change history.
    this is reckless behaviour.
    we all saw the consequences when biff tannen changed history in back to the future 2
  12. #27
    Apr 2008
    essex
    Quote Originally Posted by RedSpider View Post
    we all saw the consequences when biff tanned changed history in back to the future 2
    a very good response to a pretty pish poor post by me
    reckless??? he did help the good (biff did not)
    and he stopped miscarraiges of justice along the way and then met a bartender who "might " be god ...
    awaiting your more superior reply
  13. #28
    Feb 2009
    yes he stopped miscarriages of justice and did a lot of good work but he was coerced into doing so by his reckless friend.
    al exploited sams swiss-cheesified brain to meet his own criteria regardless of whether it was a good deed or not.
    lets say sam saves the life of a teenage boy and then that teenage boy grows up, marries and has kids.
    while, on one hand, this is a good deed, on the other it means that the boy the girl would have married instead is miserable and perhaps laer commits suicide as a result of this 'good deed.
    No, Al... NO!
  14. #29
    Apr 2008
    essex
    alas ...your reasoning is faultless
    al you are a *****
  15. #30
    i actually worked on the lhc at cern last year making the beam screens (the passageways that the protons are being wizzed around inside of)
    have got a piece of it with the cooling tubes,contact ring and sliding rings if anyone is intersted in it.
