yeah...i just tried gp2 as well...same eroor. i been trying to flash to hdd tho. should that make the dfference??
EDG-Nemesis
OoZoon
OpenPLi
DreamboxUK (OpenPLi based UK Image)
iCVS
Power Of Dreams
All Russian
Newnigma 2
Dream Elite
Merlin2 - Excalibur
dreamelite seems to be running away with it. those who have voted....please can you tell us which version you are using.
cheers.
OpenPLi 2.1 Here loving the image,
If you got a spare memory stick try it to usb alom, works fine here, btw. Make sure box is online at the time as ssl is downloaded during backup
Just wanted to say a big thanks for the help i've received mostly from the people on this thread for the help in getting my DM800SE up and running.
I've been enjoying watching football and movies this evening.
I've also been well and truly told off for inappropriate posting, for which I apologised to the Admin who contacted me. I will be more careful in the future.
Finally to complete my setup i've installed cross epg which i'm viewing with coolmans epg however not all the channels are showing info in the EPG.
There are lots of options in the cross EPG setup. Can anyone advise the best way to set this up or suggest an alternative EPG for sky UK.
Crossepg should be fine for what you require, Have you configured it for OpenTV or Rytec (or both)?
Probably better starting another thread for this also.
I refuse to answer that question on the grounds that I don't know the answer. - Douglas Adams
i run both as sometimes OpenTV wont work and vise versa. Glad to hear you are up and running. We all make mistakes
Rest In Peace Michael Mcharg, A true friend and although gone never forgotten. 11-10-08.
little update,
Just installed a samsung 500gb hard drive into dm800se, went flawless, image im using is OpenPLi 2.1, got everything working now, usb stick for storing picons, epg from crossepg,
I could get the pause, or rewind button workin on black remote, but i transfered over another keymap.xml for black remote now works perfect.
using timeshift now, and its flawless, box just breezes through bouquets while its doing that, the dm800 used to struggle abit and lag. is this really only 100mhz faster ? makes that much difference ?
there dont seem to be anywhere on openpli 2.1 where i can check hdd temp, i can see fan rpm, box is staying around 34c with lowest rpm set
lombard if theres no temp control on your image a plugin is available on Tspanel.
Would just check again under settings mate as not seen many images without it and sure I seen it on the OpenPli image but may be wrong.
im currently running the newnigma2 image , and very happy with it , only plugins im having problems with is the youtube ones,s keep getting random crashes with green screen , but the image is very stable
use this image and you won't see those probs anymore
Digital Kaos - Downloads - Newnigma2-dm800se-ssl84-sim210 -sat4fun
regarding the backing up of image. i think it's a newnigma image issue. i itries the gp flashbackup on another image and done it straight away.. come back to newnigma....same problem dosent do it.
anybody any ideas on how i can backup newnigma image please...even if by telnet.
