Hi all,
I have same problem, but my DTC is C2359.
First I tried to clear it by "W211 SBC recovery by OBD" tool, but didn't help, because this tool can clear only the DTC C249F.
I checked this DTC's (C2359-C235F) in DAS simulation in developer mode
and I guess this DTC's mean that one of the pressure sensor is wrong.
But I will check it on the weekend.
If somebody has any new information or idea, please don't be shy to let me know! :-)
If you have bled the brakes, and the code still appears, you need a new SBC hydrolic unit...
stanislav georgiev (21st September, 2016)
I found a totally safe and cheap solving! Because I'm thinking...
What is your solution?
hey guys! When it's thinking time than nobody helps, but now everybody asks?! :-) Is that fair?
Would you have preferred stupid suggestions just because you needed help? I would prefer useful inputs than just any input for helping sake. If you have challenges and got sorted out either by others or eventually through your own stroke of ingenuity which didn't come into play before asking questions it behoves you to share it with others because the truth is your are coming back and guess what, its a matter of time, others will SOON KNOW IT!!! So share it bro!
Sent from iPhone 4S
Ashraf6119 (1st February, 2015), cqae (16th October, 2013)
I don't know how exactly to help you. Maybe if you read the EEPROM of the SBC and clear the dump it will fix your problem: www.Abritus72.com
Good luck
Check your mailbox again!
even though 2 legs from 8 are not bonded, a spider is a still spider (93c86)
Hi Guys!
I asked a feedback from you about SBC repair, but I didn't get any.
Did anybody try my solution and used the car after?
Cheers!
If somebody interested in the solution, please send me a private message!
I need the exact fault code!!! So if you just interested generally, I can't help you.
I don't help for newbie and member, who hasn't minimum 10 thanks!
danyparis (3rd August, 2015), dingchavaz (29th September, 2016), hesham10 (10th August, 2020), Pali33 (2nd October, 2015), stanislav georgiev (21st September, 2016)
