Hi M8s
Anybody would let me know how to recover This SBC?
dtc C235C service threshold reached
Thank you.
Hi M8s
Thank you.
i think you should change sbc unit
pumpe work long and you have low pressure
Vheck with the dealer, many are under extended warranty coverage.
Do you have DAS Developer?. Maybe I can help.
Any suggestion, dear mates?
Hi,look in http://www.digital-kaos.co.uk/forums...3621/.:)Thanks to Qrius
there should be a ten year warranty on your sbc system
get it changed as the back up system is not that good if it fails
i have seen dealers here change them with 300,000 miles on taxis free of charge you can do reset with diag but why when you can get new fitted free
Hi all,
I have same problem, but my DTC is C2359.
First I tried to clear it by "W211 SBC recovery by OBD" tool, but didn't help, because this tool can clear only the DTC C249F.
I checked this DTC's (C2359-C235F) in DAS simulation in developer mode
and I guess this DTC's mean that one of the pressure sensor is wrong.
But I will check it on the weekend.
If somebody has any new information or idea, please don't be shy to let me know! :-)
If you have bled the brakes, and the code still appears, you need a new SBC hydrolic unit...
stanislav georgiev (21st September, 2016)
