Put flux on complete EDC board, and reflow complete ECU.
Problem is VIA.
PS
Hi.
I have EDC16C39 0281012193 ECU not driving 1 and 4 injectors.
The engine is running but only 2 and 3 cylinders are working.
EDC Lamp is ON.
I have checked all transistors, diodes, fuses and they are all good.
Replaced Mosfet driver IR20153S that was driving a transistor which powered 1 and 4 injector +.
Replaced Bosch 30520 (IC driving injector mosfets).
Finally i thought that it could be a bad joints under MPC562...
I have reballed MPC and soldered it back - still not driving 1 and 4 injector
Any advice?... what can it be?
Problem is VIA.
PS
Do you fix it ?
BRS
My work is my life ART TECH GARAGE
What do you mean width VIA
thank"s in advance
This ECUs are very fragile.
If You bend pcb too much it's over.
I have 2 or 3 ecus broken like this and never repaired it because the problem was in the PCB.
The only way is to buy a second hand ecu and clone it by BDM.
any fix problem? same problem now
thx guys
LOL so im not the only one , i have 1 ecu also just driving 2 injectors and other one driving no injectors . did it all replaced the 2 big transistors ect basicly replaced all the transistors even the diodes and the didodes that looks like eeproms and the 2 bosch chips . reflowed yhe whole board even compared a working ecu components placing and values . can not find any fault . my only conclusion is that when it was opend the 2 boards made a seperation between them and lost contact ore something like in post #6 . now i have more spares woopy
Ask a dumb question and become wise for the rest of your life, but act wise and stay dumb
typically damaged BYV32-200 or similar
Iveco only.
