Page 7 of 11 FirstFirst ... 234567891011 LastLast
Results 91 to 105 of 156
  1. #91
    Newbie rubiconrojo's Avatar
    Hello all,
    I?m newbie with CALTERM III sw tool. I need to change max RPM and increase 250 RPM due to application on QSL9 ECM 850 , ECM CODE W90572.02, ECM part number 4921776, option DO 90921, option SC 9621. The thing is I know is necessary special files to access to ECU with CALTERM. As I red in other threads, for old engines is necessary e2m files but for new core ECM and COMMON RAIL engines is necessary cfgm files. My doubts on this matter as follow:
    1. Every ECU has its own file to access with CALTERM and modify parameters and calibration or is for family engine, application, SW fase or options on engine? So, is there a family ECU file or unique for any individual ECU?
    2. What is exactly the function of this files to use CALTERM and access to ECU? With INSITE we don?t need any special file for any family ECU or engine!!
    3. CALTERM it doesn?t have internal generic files to access any ECU in standard mode? let?s say
    4. Could be possible this files are the arrange map or internal memory dealing with microprocessor and how to access them and modify?
    5. Someone can explain how to upload the file to CALTERM and then comunicate with ECU? I tried, but with no success to connect ECU!!!
    6. Someone can provide the file for QSL9 ECM850 with data I mention above? It?s really necessary to increase this 250RPM
    7. Anybody did this change before to increase RPM limit on this ECM? Is associated to any parameter to be modified by CALTERM.
    Any advice, guidelines or "tricks" on dealing with CALTERM would be really apreciated, I?m getting started.
    Thanking in advance to everybody .
  2. The Following User Says Thank You to rubiconrojo For This Useful Post:
    park5472 (13th March, 2019)
  3. #92
    I am looking for the ecfg for a CM2250 so I can upload a calibration.
  4. #93
    Jul 2012
    USA
    Quote Originally Posted by rubiconrojo View Post
    Hello all,
    Here is the ecfg file for your engine. You can sometimes use a configuration that doesn't quite match, but I got your calibration off the incal disc and tried it and this matches exactly.
    I haven't used incal whole a lot yet, but I believe the function is just to define where all the maps and settings are in the ecu.
    I`m not sure how to go about increasing rpm limit.
    I also attached a guide that may help with learning how to use calterm.
    4980235-CM850_pn3954430_15.1.0.11.zip
    Calterm Guide.zip
  5. The Following 25 Users Say Thank You to jr2185 For This Useful Post:
    albeezim (31st March, 2015), alxmena (6th May, 2021), DewDewMax (11th April, 2019), edievoid (22nd February, 2019), Elvic57 (2nd August, 2017), fmf2190 (31st July, 2021), hrobertdm (21st July, 2016), Israel07 (3rd October, 2014), joe gp (9th October, 2014), Juanincho (2nd August, 2017), kamaleon (14th August, 2016), kotok008 (4th September, 2018), mentos (11th November, 2015), park5472 (12th March, 2019), peter21 (26th October, 2014), Poptest (29th March, 2015), rdjorge (5th March, 2019), Rerouter (4th November, 2014), rubiconrojo (21st August, 2014), smokery (9th May, 2019), tap50 (11th January, 2015), tatyanka (9th March, 2015), TIGER24 (18th February, 2018), vulep (12th October, 2014), whalla (28th June, 2017)
  6. #94
    Jul 2012
    USA
    Quote Originally Posted by frankiegr View Post
    Try this one.
    ecfg.zip
  7. The Following 18 Users Say Thank You to jr2185 For This Useful Post:
    alxmena (6th May, 2021), dp12fix (12th September, 2016), frankiegr (18th December, 2014), gitano (4th November, 2015), je69 (2nd November, 2015), Juanincho (2nd August, 2017), kamaleon (14th August, 2016), kotok008 (20th November, 2015), Louie (12th January, 2015), mentos (11th November, 2015), peter21 (26th October, 2014), proudolive (21st June, 2015), rdjorge (5th March, 2019), reebok90 (25th June, 2018), smokery (9th May, 2019), swpark (12th March, 2019), TDT (20th September, 2019), valero (29th September, 2015)
  8. #95
    Top Poster + shisik's Avatar
    Sep 2011
    RUSSIA St. Petersburg
    please help!
    i need E2M file for ECM PN 49217776 ISLe4 AAJ AP90031.cal
    or please PM
  9. The Following User Says Thank You to shisik For This Useful Post:
  10. #96
    Default ECFG File
    AP90031.05.rar
    Quote Originally Posted by shisik View Post
    please help!
    or please PM
    Try this file
  11. The Following 4 Users Say Thank You to alsop For This Useful Post:
  12. #97
    Sep 2011
    Quote Originally Posted by alsop View Post
    AP90031.05.rar
    Try this file
    thanks ))) this cal file
  13. The Following User Says Thank You to shisik For This Useful Post:
  14. #98
    Sep 2014
    Hey there guys.. Does anyone know if it's possible to get newer ecfg files for the cm871? I have rawzes but the June 2014 disc does not match. Thanks
  15. #99
    Dec 2010
    Password please
  16. #100
    Member 3stigi4's Avatar
    Hello guys help me with insite 7.6.0 i need the key pro plus please my PCID 3AD04A25 please and thanks
  17. #101
    Rerouter's Avatar
    Jul 2014
    Australia
    Hello, I am looking for the ecfg file for a ISL 8.9Ltr CM2150, 2011 Manufactured year
    I am hoping to disable the Adblue system,
  18. #102
    Hello jr2185,
    First of all thanks so much for the file, at least now I can connect to the module but I can not upload calibration, at 12% always got error of downloading. Do you have original calibration for that ECM. I know is a file with extension .xcal Do you know how i CAN GET iT FROM incal dvd. I have some incal dvd but I can not read or extract calibration from them. I guess I need calibration load on CALTERM and then editing calibration on parameters or look up tables and download on the ECM. Now I?m concern to damage ECM if I try to download something wrong. At lest I would like to have ori calibration just in case.
    Thanks a lot for your help is really useful for me.
    Kindesr regards.
  19. #103
    Post the Incal calibration you want converted to CaltermIII format. PM me and I'll convert it to xcal for you.
  20. #104
    Alsop,
    Here you have the file.
    Thanks.
  21. The Following 2 Users Say Thank You to rubiconrojo For This Useful Post:
  22. #105
    Default Converted file
    Here is the calibration converted to Calterm format. You can view it with word pad. Use winrar to unpack and save where ever you want. The original file won't have an extension xcal until you edit it and save it with the program. You do have the correct .ecfg file and everything should work fine.
    W90572.rar
    This is a link to Calterm on how I used Calterm to edit some files in an ISM
    http://www.digital-kaos.co.uk/forums...ml#post1855245
  23. The Following User Says Thank You to alsop For This Useful Post:
    rubiconrojo (23rd January, 2015)
