pc id DC-8A-40-7A-98
unloc code 35-7C-A9-6C-91
pc id 92-b2-18-0a-4c
unlock code 7B-44-F1-1C-45
Hello friends.
Someone to share crack or keygen for this program's ?
Thank you very much.
Ok, with key drumroll opens but after 30 seconds or so it gets an error and shuts down.
when I look at the error report it says that my system is running windows nt 5.1 and that I have an AMD processor. both of these things are wrong
My Drumroll would hang up for a long period of time then get an error message (I don't remember the message). I had experienced a similar problem with DDRS unless the my USB Link was connected to my computer. I connected my USB Link before opening Drumroll and no more hang up or error messages. I an running this on an Acer Netbook with an Atom processor and XP Home.
Emgo
I tried it with the usb link pluged in
Hello friends.
I installed this program but I get an error message.
What problemma?
Who installed and successfully working?
you can do this...
c/program files/diagnostic link. then copy and paste here the Branding.dll. you need to use the file only with this name "Branding.dll" rename if it need and use the correct one, there ar two craks, 7.06 and 7.07 each one for each version. good luck.
I think maybe my problem is I used a crack for dddl7x and crack gives wrong computer id and doesn't work for ddde. i'm looking on my computer for dddl 7x. and i can't find it at all, does the newer dddl run as ddrs?
Please share Drumroll 7.03
Hello friends.
I installed this program.
When you first start, it requires registration.
Who uses this program?
Please help me.
Thank you.
hello, does anyone use noregon DLA +
to connect? connectivity test says has
has connection & traffic j1708, j1939,
can 250k but will not connect. please
help thanks.
