Once you are connected to both cpc and mcm, export the parameters to your computer. Then, locate folder in which the files were exported, and open them with a spreadsheet editing program.
Can I please get a key for Computer ID # F8-F1-98-0C-0C
Wayne64SS (30th May, 2013)
please i need key for ddde 7.6 MY PC ID IS 9E-D1-76-9F-75
Hello people,
Can you help me to get an Acces key to DDDE 07.00-00505-00008.
My pc id is 89-96-5E-F3-2A
Jear (16th July, 2013)
hi friend anyone know how eliminate the dpf shutdown from ddec vi ecm here in venezuela this system is a big headache
hi friend i got a question, how can modify inputs and output for engine mbe 900 and 4000 equiped with pre-ddecvi electronic controls. i know that dddl 6.46 has and option to activate engineering data but ask for a key with 3 digit. thanks in advance
Looking for access key for comp id B5-75-B1-EB-28
What's the difference between this D.D.D.E and D.D.R.E.? What Detroit engines do they work on?
Hello everyone:
I just installed DDDE 7.06 and have Read 3, Write 3 and Product 4. Program work fine on viewing Fault Codes, Instrumentation, Parameters and all others. The problem I notice is that I can not make any changes to parameters such as speed limit, HP, or even perform testing on Cylinder Cutout, Delta Calibration. It will give me a message negative response or the program shut down. I am using this on Window 7 32 bit. Not sure if this is the problem. Any one has a clue?
