Recover Dead Skybox/Openbox Flash Using Serial RS232 Null modem Cable - Page 2
Page 2 of 53 FirstFirst 12345671252 ... LastLast
Results 16 to 30 of 789
  1. #16
    Maybe comm port issue.
  2. #17
    Dec 2011
    Quote Originally Posted by Manic01 View Post
    any idea for this issue? pls advice
  3. #18
    Apr 2011
    well done southpaw u finaly got it working, i stil cant get mine working and i dnt even know wha firmware i had last DAMN
  4. #19
    Apr 2011
    Quote Originally Posted by miziee83 View Post
    try using com 3
  5. #20
    Member darvash's Avatar
    Copenhagen Denmark
    If you cannot contact to your box check your null modem cable. Connections are like showen below
    pin 2 ...to... pin 3
    pin 3 ...to... pin 2
    pin 4 ...to... pin 6
    pin 5 ...to... pin 5
    pin 6 ...to... pin 4
    pin 7 ...to... pin 8
    pin 8 ...to... pin 7
    Important: Go into device manager and check that you are choosing the right com port. If possible use computer with serial com port build on mainbord.
    *****Don?t argue with idiots. They drag you down to their level and beat you with experience*****
  6. #21
    Jan 2012
    Question
    I have a problem to upload a firmware by RS-232 : Synchronizing STBs... Please reset target!
  7. #22
    Jan 2012
    Quote Originally Posted by jouhz56 View Post
    I'm experiencing the same exact problem for some damn reason. I've tried about everything I and darcu could think of. Not sure what to do anymore.
  8. #23
    Feb 2009
    ok manage to contact box in step 1 but have com test error in step 2 any ideas using a null cable with usb adaptor
  9. #24
    DK Veteran slugworth's Avatar
    Nov 2011
    new england
    make sure usb adapter is com1
    good luck,not many people have good results with adapters.
  10. #25
    Mar 2012
    greetings people of the box, my skybox is finally dead after i update the TP_PROG, not sure if its the SW or theres sumtin wrong wit the power supply.. just got my null cable today, hope sumtin good will happen.
  11. #26
    Mar 2009
    Default Openbox s11
    Hi guys, I'm having a constant rebooting problem with the Openbox s11. Would this method work with the s11?
    Cheers
  12. #27
    Mar 2012
    will this bring a deadbox back to life and what is the best image to reload
  13. #28
    Apr 2012
    Hello everyone,
    I have one Openbox S10 clone killed by official firmware... when i try recovery Eromupgrade say "COM TEST ERROR"
    why is this?
  14. #29
    Apr 2012
    I have a dead OpenBox S10 that I'm trying to unlock. It says I need to post to download posted fixes. Also could use some advice from someone who's done this. ...thanks
  15. #30
    Apr 2012
    Default stuck
    Same here nothing work with mine after update ok but adding tpprog kill mine ...
