Recover Dead Skybox/Openbox Flash Using Serial RS232 Null modem Cable - Page 3
Page 3 of 53 FirstFirst 1234567813 ... LastLast
Results 31 to 45 of 789
  1. #31
    Apr 2012
    Default Can't get my Openbox to flash
    Quote Originally Posted by Zibi1 View Post
    Why I can't downlad any software for my openboxs10 ?
    I only get an error when i try to flash my box true rs232
  2. #32
    DK Veteran slugworth's Avatar
    Nov 2011
    new england
    your timing is off,using the wrong cable,or using the wrong version loader.
    You have to start the loader hit next then casually turn the receiver on.
  3. #33
    Apr 2012
    Quote Originally Posted by miziee83 View Post
    why i cannot...
    the massage as below
    synchonizining STBs
    please reset target!!
    pls help me
    im also like this
    how to fix it?
    how to reset target?
  4. #34
    May 2011
    have you checked your com port setting (device manager)
    port settings
    bits per seconds :115200
    data bits :8
    parity :none
    stop bits :1
    flow control :Xon / Xoff
    if your settings are the above then Slugworth makes good sense. check loader is selected with a tick applied timing start software before switching receiver on at right moment 7-10sec
  5. #35
    Nov 2011
    new england
    a moot point,since the program itself takes control over the comport when used.
    I never mess with the windows default setting,which I believe are a lot different.
    the loader uses even parity BTW.
  6. #36
    Dec 2011
    prestopans
    Default boot
    hi , can anyone help, i have a skyboxs12 it has stuck on boot i need a 4pin to rs232 adapter can anyone tell me where i can get this or show me what it looks like.
    thanks pisher
  7. #37
    May 2012
    Hi i am also getting synching stbs ..
    please reset target
    but i have rs232 to lpt port no rs232 to rs232
    could that be my problem
    my box is constantly rebooting
  8. #38
    Nov 2011
    new england
    loader needs a real rs232 port to function.
  9. #39
    May 2012
    isn't there a dos command or a windows utility to redirect lpt to a com port
  10. #40
    Nov 2011
    new england
    make friends with somebody with an old pc
  11. #41
    May 2012
    ok i got a null modem cable,was not working ,then i plugged it in com1 and gave the stb erom com2 instead and finally got it ALIVE again . . .
  12. #42
    Darvash
    I dont know if you will read this post but I thank you as you saved an s10 for me which would not boot.I followed your instructions and it saved my s10
    Thank you.
  13. #43
    Jan 2012
    hi is there anyway i can use the null cable on a laptop? as i do not have a pc
  14. #44
    Nov 2010
    Quote Originally Posted by santino View Post
    hi there does anyone know where i can get good c lines from?
    You have to read the rules m8 cant discuss that here. Google is your friend here.
  15. #45
    Nov 2010
    You can with a usb to serial adapter, for some people works fine for others it doesnt. What os system do you have on your lappie.
    Usually better to have a dedicated serial port.
