Page 13 of 53 FirstFirst ... 38910111213141516171823 ... LastLast
Results 181 to 195 of 789
  1. #181
    Oct 2012
    Default OPENBOX
    hi.. i'm new here... i've installed some clone safe firmware .. but on my box dont work the network.. how can i solve?
  2. #182
    Newbie flatdish2's Avatar
    Jul 2008
    Quote Originally Posted by dennyseven View Post
    Bro try this...press menu then press 666 you can see network menu..
    regard
  3. #183
    Oct 2012
    Germany
    I try this solution on my Openbox S16 with reboot loop. Hope it works
  4. #184
    Nov 2012
    my skybox f3 hand at 0090..why?
  5. #185
    Aug 2011
    Is any use of Openbox S1
  6. #186
    Nov 2012
    Quote Originally Posted by beats2006 View Post
    Ok I was having the same problem and just fixed it finally after a lot of trial and error heres what I did -
    downloaded http://www.digital-kaos.co.uk/forums...de_8mflash.rar
    then downloaded some older firmware -
    SKYBOX_3601hd_CMT_120820071a.abs
    (if you search google you will find it)
    Then I plugged the box in and attached the null modem cable,
    opened up the erom upgrade folder and ran CONFIG.BAT
    then ran EROMUPGRADE
    Selected the firmware I downloded
    Ticked Include Bootloader
    Clicked next
    when it says-
    synchonizing stb
    Reset target
    I unplug and replug the power cable out of the back of the box quite fast it will then let you carry on and recover the box
    once recovered you can update to a later firware via usb or the X3 Lan tool.
    hope this works for you as I was pulling my Hair out yesterday
    I?ve tried soo many times and failed...how on earth did you manage?
  7. #187
    Nov 2012
    Quote Originally Posted by slugworth View Post
    rs232 cable only needs 3 wires,pins2,3,5
    2-3,3-2,5-5
    Is this really true?
  8. #188
    DK Veteran slugworth's Avatar
    Nov 2011
    new england
    look inside the receiver.
    there are only 3 wires going form the connector to the mainboard.
  9. #189
    Nov 2012
    i oso hving a same problem on my openbox s10. only display On. so now i will try to flash it..see can recover or not..anything will upgrade here ....TQ all the menber
  10. #190
    Nov 2012
    I am trying to download a .abs from openbox clone for back which tool do you recoment, with ALI Editor I can only download user data file (.udf), STB re boots and displays A H on the LED screen
  11. #191
    Nov 2011
    new england
    alieditor has a choice of files types at the bottom of the screen,change it from the default .udf to .abs there.
  12. #192
    Nov 2012
    Yet another generally happy Skybox F3 user - but I too have bricked my Box after uploading a TP_Prog.dbs file that I'd dumped to Edit using the supposedly pukka Editing Tool. It corrupted the file and left the Box in the Boot to L100 then go round again ad infinitum loop.
    Downloaded the Recovery Tool from elsewhere, but it doesn't have the config.bat element that is mentioned in this Thread and although it syncs with the Box ok I get the Memory problem report.
    Have taken note of the comments about waiting a good few seconds before powering up the Box and will try again tomorrow with the Recovery Tool linked in this Thread.
  13. #193
    Nov 2012
    Success!
    Worked first time: Made sure to run config.bat (No idea what it does, but hey-ho!) first then the EPROM tool, taking note of the ReadMe file.
    Selected an earlier .abs file than the one I was using before it all went wrong.
    Turned Box on after 10 seconds and waited a few minutes until it had done its thing, saw L100 come up and replaced by Strt then NoCH.
    Uploaded TP-PROG.dbs from a known working Dump, twiddled a few system settings and am now a happy bunny.
  14. #194
    Nov 2012
    Have fun[/QUOTE]
    [spoiler][QUOTE=darvash;1293030]A how to guide on how to fix a corrupt firmware image in the OpenBox S9/S10 and Skybox S)/S10 Even if it seems bricked.
    This guide is taken from another forum so big thanks to auther.
    Box does not respond or displays On?
    If your box does not respond, or no displays light there is a good chance the current firmware on the box is somehow corrupt.
    You will need to use this tool, connect a Serial RS232 Null Modem Cable to the box and follow the instructions.
    Hopefully it will bring your box back to life.
    instructions
    Download the file:- "Upgrade_PVR800_HD_Tool.rar"
    Unzip this file & you have a folder with 5 files:-
    eromclient.abs, flashburn.ini, sdram.ini,
    LZMA.exe & eromUpgrade.exe & helpfile.txt.
    1. Connect up your PC to the Openbox
    using a null modem serial cable.
    2. Switch the box OFF
    3. Run EromUpgrade.exe then check the
    com port setting is correct
    4. Select the latest firmware .abs file. (Download her if you don't have any)
    5. Select "next" then switch ON the box
    and follow the instructions to load
    and flash burn the firmware.
    6. If the process does not start, try
    various time combinations of switching
    the box ON after selecting "next"
    7. Don't switch the power off or disconnect
    while the download & flash is taking place.
    If you cannot contact to your box check your null modem cable. Connections are like showen below
    pin 2 ...to... pin 3
    pin 3 ...to... pin 2
    pin 4 ...to... pin 6
    pin 5 ...to... pin 5
    pin 6 ...to... pin 4
    pin 7 ...to... pin 8
    pin 8 ...to... pin 7
    Important: Go into device manager (goto start-->run-->type "devmgmt.msc" )
    or right click MyComputer--->manage--->on the left side u find device manager
    and check that you are choosing the right com port. If possible use computer with serial R232 com port built on mainbord.
    [/spoiler]
    i have problem to conect my tool n port serial rs232, i will flashing my DVB, please give me explanation sir , let me give some for you
  15. #195
    Nov 2011
    new england
    openbox only uses 3 pins
    2-3
    3-2
    5-5
