Recover Dead Skybox/Openbox Flash Using Serial RS232 Null modem Cable
Page 1 of 53 1234561151 ... LastLast
Results 1 to 15 of 789
    Member darvash's Avatar
    Copenhagen Denmark
    Default Recover Dead Skybox/Openbox Flash Using Serial RS232 Null modem Cable
    A how to guide on how to fix a corrupt firmware image in OpenBox S9/S10/S11/S12 and Skybox S10 F3 F4 F5 F5S A3 etc. Even if it seems bricked.
    Box does not respond or displays On or rebooting constantly ?
    If your box does not respond, or no displays light there is a good chance the current firmware on the box is somehow corrupt.
    You will need to use Skybox_openbox _flash_tool.zip, connect a Serial RS232 Null Modem Cable to the box and follow the instructions.
    Hopefully it will bring your box back to life.
    instructions
    Download SKYBOX _All_ Upgrade TOOL.zip or openbox_s9_s10_s11_s12_Flash_RS232_tool.zip if have older Openbox/Skybox
    Unzip this file
    1. Connect up your PC to the Openbox
    using a null modem serial cable.
    (Try to get a PC with builtin r232 port or buy a good quality usb to seriel adapter. Cheap adapters from flebay "do not" work at all)
    2. Switch the box OFF
    3. Run EromUpgrade.exe (Located in folder you have downloaded and unzipped) then check the
    com port setting is correct
    4. Select the latest firmware .abs file. (Download her if you don't have any)
    5. Select "next" then switch ON the box
    and follow the instructions to load
    and flash burn the firmware.
    6. If the process does not start, try
    various time combinations of switching
    the box ON after selecting "next"
    (IF it comes with set STB memory error please run config.bat file (Located in folder you have downloaded and unzipped) ) before running loader
    7. Don't switch the power off or disconnect
    while the download & flash is taking place.
    If your box keeps rebooting after updating so try software from http://hddvbsw.com/index.php?c=key_download
    If you cannot contact to your box check your null modem cable. Connections are like showen below
    pin 2 ...to... pin 3
    pin 3 ...to... pin 2
    pin 4 ...to... pin 6
    pin 5 ...to... pin 5
    pin 6 ...to... pin 4
    pin 7 ...to... pin 8
    pin 8 ...to... pin 7
    Important: Go into device manager
    <right click MyComputer--->manage--->on the left side u find device manager
    and check that you are choosing the right com port. If possible use computer with serial R232 com port built on mainbord.
    Have fun
    *****Don?t argue with idiots. They drag you down to their level and beat you with experience*****
  2. The Following 55 Users Say Thank You to darvash For This Useful Post:
    acres09 (9th February, 2016), ak005 (4th August, 2013), alwurzel (4th July, 2013), ammo92 (3rd November, 2013), Arnather (8th June, 2013), BlacksunLE (7th April, 2017), Ch00ng (16th August, 2014), cooper 8 (7th September, 2014), dbj159 (13th October, 2014), fishy (31st December, 2015), fivesnakes (16th September, 2014), frankbeer (19th April, 2013), Gokhle (24th June, 2013), grim89 (26th July, 2013), happygrl (3rd May, 2015), harold566 (14th August, 2014), Holzwurm0101 (31st August, 2014), ili7107 (20th July, 2020), JDavid22 (27th December, 2022), jimbojimjay (1st October, 2015), jimmy230 (11th April, 2013), jimmynewbie (5th July, 2013), jolatacqce (26th August, 2014), jvcd100ek (20th November, 2014), kiko44 (7th February, 2016), kimosohara (25th November, 2014), kuachan (25th March, 2015), lekir (18th December, 2014), Lucky1966 (21st April, 2013), mackin (28th February, 2015), mandarinas666 (4th May, 2014), Markymark49 (16th December, 2014), master28 (10th May, 2014), MAX2504 (20th August, 2014), miele (23rd June, 2016), Mysteriousguy (23rd August, 2013), paquito2014 (14th May, 2021), PeterAcko (13th September, 2014), polly4you (18th September, 2020), puente387 (8th July, 2014), rick2021 (8th April, 2014), rrodclos (29th June, 2013), saerhassan (21st March, 2015), stualdo (26th February, 2015), stuh10 (4th February, 2017), tunnaing52 (5th January, 2014), TurboPirate (28th January, 2014), undernaz (21st November, 2014), utdman (19th August, 2013), vekas15 (8th November, 2013), vincenzocarduci (20th August, 2014), vitormik (7th September, 2017), x1245 (23rd November, 2015), zfdesign (5th January, 2015)
  3. #2
    Nov 2011
    my openbox s10 cant boot! only show the ON on the display...this guide work 4 me?
  4. The Following User Says Thank You to hykung For This Useful Post:
  5. #3
    Nov 2011
    Default constant reboot issues openbox s11
    I have the constant reboot issues too on an s11 box.
    Have tried removing the dish cable, but each time I go into the menu and try to getting to system setting, the box reboots.
    Am now trying to flash using a null model cable, but it's stuck at 99%.
    Any advice anyone?
    Thanks in advance.
  6. #4
    Dec 2011
    it says synchronising stb
    please reset target
    so do i still try to press next and on and off the openbox?
    DK Veteran slugworth's Avatar
    Nov 2011
    new england
    Post pdf
    Quote Originally Posted by ming930919 View Post
    please reset target
    a pdf I found with one of the ali loaders.
  8. The Following 7 Users Say Thank You to slugworth For This Useful Post:
    alwurzel (4th July, 2013), daithi (2nd March, 2017), fivesnakes (16th September, 2014), JDavid22 (27th December, 2022), luisanimal67 (29th November, 2018), pablo1971 (19th July, 2015), TurboPirate (28th January, 2014)
  9. #6
    The Stig PT mtv1's Avatar
    Apr 2008
    Tipperary
    seems to be a flood of open boxes coming to the market
    1 if it works filmware wise leave it alone
    just add tp-prog file
    always check is it a clone here
    http://www.digital-kaos.co.uk/forums...4/#post1297641
  10. #7
    Nov 2011
    new england
    Exclamation fiasco
    Quote Originally Posted by mtv1 View Post
    That's what started the fiasco.
    When I bought mine it had a sat list for the wrong side of the earth.I tried to load a tp_prog from a forum site and it wouldn't turn on after that.Apparently it was a mismatch to the firmware that was loaded.I had to use the rs232 loader to recover and got factory firmware and tp_prog from the seller to start fresh.
    After that I don't load any foreign channel lists,no matter how lazy I feel.
  11. #8
    Top Poster Digicom's Avatar
    I have Openbox S9 which when powered up just displays On.
    Tried using EromUpgrade tool but it never goes any further than "Synchronising Stb please reset target".
    Even left it for 30 mins with that message but it does not go any further.
    Any help would be apprciated
  12. #9
    merseyside
    Quote Originally Posted by Digicom View Post
    if you try various firmwares , one should eventually connect , had same problem myself but eventually had a hit , will try find out which f/w i used if your still struggling.
  13. #10
    Apr 2011
    hey southpaw can you remember which f/w u used still cant get mine to connect erom says set upgrade mode error tried various f/w but none will flash any advice greatful am about to give up on this s10 not getting anywhere
  14. #11
    merseyside
    Quote Originally Posted by scottj130208 View Post
    after weeks of trying i got in touch with the manufacturer who advised me (in broken english ) that to recover try the last known working F/W you had on the box (bfore it errored) and work backwards from here , Got mine going in 3 tries using the last known working f/w ,
    this was on an S9 , but hopefully it will work for you on the s10
    good luck mate
  15. #12
    Top Poster Dub12Dave's Avatar
    Feb 2011
    Dublin Ireland
    Great news southpaw glad you finally got it sorted.
  16. #13
    Thanks for reply and if you could find out wat firmware worked for you as i am struggling
    regards
    Quote Originally Posted by southpaw View Post
  17. #14
    merseyside
    the firmware i recovered with was 20110315
    however that was the last working f/w my box had before bricking
    just load your last known working f/w before you bricked it mate
  18. #15
    Dec 2011
    why i cannot...
    the massage as below
    synchonizining STBs
    please reset target!!
    pls help me
  19. The Following 6 Users Say Thank You to miziee83 For This Useful Post:
    egyhamid (19th March, 2017), kaneramsden1991 (14th January, 2014), mujdat (4th January, 2014), newgoal (9th January, 2016), rbetb (1st May, 2017), shahnawaz (18th October, 2014)
