Help to install MGcamd
Results 1 to 15 of 17
    Oct 2011
    Default Help to install MGcamd
    Hello i m new in satellite.
    I have TGS210 and i want to install mgcamd. I have ur image. I put the file in temp and when i try to install did not start the installation.
    Top Poster Millzzy's Avatar
    Hi frogky , I'm having the same issue which a few of us are trying to resolve itgates seem to be a bit choosy as what they like installing I will keep trying also but if u have any luck please post back
    DK Veteran freck's Avatar
    Jul 2008
    Dark side of the Moon
    Bang this into tmp and manual install
    May 2008
    freck have you managed to instal this into a ukur image?.... i,v tried many but cannot..
    Jul 2008
    Yeah I've it working here on V8 Ireland edition UKUR...no probs with it but I can recall getting it working on Nemesis aswell.
    Better of changing to MGcam as CCcam is wide open!!!!
    Only prob with that is you need a server that'll cater for it.
    Ive both coz my guys are a step ahead of things over here.
    Try it out and let me know....manual install
    If yere still having trouble I'll look further into it
    Freck
    Jul 2008
    Heres V8 if you need it
    Freck
    Maybe time to try a diff ukur image , cant get the ukurV9 image to recognise anything but a tar.gz file in the temp folder Freck , when i get file recognised just says installing then nothing happens
    Jul 2008
    Try Nemesis or V8 Ireland Edition with the .tbz2 file and se how you go.
    Freck
    Oct 2011
    Quote Originally Posted by freck View Post
    Freck
    Hi freck...I tried Nemesis and it worked but i have another problem.. I can't find channels of Hotbird. Can you suggest me another image that it work with Hotbird?? Receiver TGS 210/220
    Aug 2008
    Wild Mild West
    Why dont you load a set of bouquets using dreambox edit with hotbird like the captains or vhannibals bouquets ?
    ITgate TGM220 (swapable tuner), Dreambox 800 pro, Dreambox 500c x 2, DBox, Popbox media player.
    Jul 2008
    Quote Originally Posted by frogky View Post
    Download what you need from Vhannibal.load up the file with DBEdit and send over to ITGate...job done.
    Freck
    Jul 2008
    Heres a working Mgcamd...just took it off my unit.
    Guaranteed working 100%
  13. #13
    Nov 2011
    i have the same problem...i put the file in to the /temp and when i start the install manual it's start but stack there....i try this file and i tell you ( mgcamd_135.tar.gz).. i am new in this so be easy
  14. #14
    plasterer's Avatar
    Jun 2008
    Mersyside
    Why you useing mgcam mate
    Cant you use CCcam that downloads straight from the panel ....
    Hope this helps .............Paul
    PAUL
  15. #15
    May 2008
    only reason i can think of that they may need summit to help with high ecm times?.. i guess
