copy contents of cccam onto desktop as it is,(dont unrar it)
ftp using filezilla or even better dreambox control centre E2 into tmp folder in the vu+ uno setiings folder or content folder.
then using control centre again connect to box ftp go to etc
go into cccam cfg file edit,delete all contents,insert line then save exit.
turn Vu off at back back on again go into green button then yellow button then install adons activate cccam make it default.
should all work..........so easy when you get it together but hard to do when your a novice,ha ha good luck everyone.
