Kuciap (25th November, 2022)
Hi I need Toggleable pops and bangs in x3 e83 m54b30 ms45
Hi, need help with o2 removal in med9. I edit some switches, but check engine is visible. Can anyone look my file, and edit or give some tips on pm?
Pls Lancia delta 1.9 190hp edc16c39 more power
Hello ,
can some one please remove only DPF on this file ?
best regards
Best Regards 03L906022B audi a4 b8.rar
btw one queston ?..... this is my father's audi a4 and he removed dpf because it was in peases and blocked the pipe and the car dident start . and now when i write a ecu file with stoped dpf everything works and doesent give error but he says to me that in the city the car diesel use is 9-10 l/100 km .... is it possible that the car started a dpf regeneration and did not finish (because blocked dpf and now when it doesent have dpf and file that removes all dpf codes and dpf switch is set to 0 ) and now the injectors are non stop puting dissel in the exoust and this is why it uses 9-10 l /100 km in the city?
I understand that not everyone is lucky
Hej can someone help me with speed limmit
Hi, i buy car with already remap ecu but the engine dies when full throttle is pressed. Can someone help
e46 m57 135kw
Hi! Can you tell me at which map address I can activate the cruise control in VW Lupo 3L?
VAG: 045906019Q
Component: 1,2l R3 EDC 0001DS 0920
Soft. Coding: 00002
VW lupo 1.2TDI 61HP 045906019Q_0281010258_352999.zip
bad remap?
can fix?
