digger75 (13th March, 2016), Quinton (24th August, 2022), Vagabond90 (15th October, 2020)
Last edited by motocarlos; 6th April, 2012 at 09:54 PM. Reason: i forget the attach file
WORK WITH KWP 2000+, GALLETO 1260, BDM 100, FLASTEC CLONE WITH MAGPRO2, VAGCOM, FIAT ECUSCAN,UPA USB, MAXIDIAG, TOP 2049, PROG EXPRESS, AND MORE....
digger75 (13th March, 2016), eliah (16th January, 2019), Vagabond90 (15th October, 2020)
Hi, for my Peugeot 307 2006year 1.6 hdi 110 kw need egr off and if posible - remap. Please help. Thanks.
MagicMotorsport FLEX, Kess / K-Tag original, PCM Flash, MMC Flasher, BitBox, 2wd Dynomet Dyno Road, Ori WinOls.
We offer: Cars, Trucks, Agro, Construction Machines Tuning / DPF / EGR / Flaps / Throttle / Ad Blue / Lambda / DTC, IMMO off. Also EDC17 IMMO off BY EEPROM with no faults on a dash!
?Please Take note that DK forum or any user, takes no responsability for the use of files or damage that can cause to you, your vehicle or 3rd party!
need tuning for my car
VW Passat CC 2.0tdi 140HP common rail
I would like more horsepower, it is possible to change the torque, opening time of the turbines and anything else to achieve this ?
I don't want to turn off the DPF/FAP and EGR.
The flash was read using MPPS v5.
thanks in advanced
Hello friends. Someone can help me? I need to file for more power. AUDI A4 2.5TDI (163). ECU 8E0 907 401 Q
Thank you very much.
I need tunned file and hot start problem remove
Bosch Software Number: 1037381351
Vw Software Number: 03G906021LP
System Type Number: R4 2,0L EDC
I need more power for this file of Altea 1,9TDI 105HP. I haven?t driver for this file. I need +40hp aprox.
Thanks in advance.
I need tuning for my car
fap is off now but I need max power
Peugeot 307 year 2002 edc15c2
HW:0281010779
SW:1037353725
Thanks in advance.
I need EGR OFF for Mercedes Sprinter.
Mercedes Part Number : A 612 153 22 79
Mercedes Ecu Type : ED6026 CR2.36 2.7L
Mercedes Hardware Number : 14.00
Mercedes Software Number : 39.00
Bosch Part Number : 0 281 010 614
Bosch Software Number : 1037351491
Thanks in Advance
5WK90008 INDEX 02 2001
Please help me remove speed limit in my ecu(mazda bt-50 ecu edc16c7) I read rom files via BDM100 .
thank in advance
file for ARVEDO
