oski94 (15th June, 2018)
Hi mate. Would you be able to tune a bmw e46 330ci that has had a turbo installed. MS43. I have Xdf files but only for tuner pro. Can flash 64kb or 512kb no need for checksum correction
ashm431313 (16th June, 2018)
Please folks. Help me too. I have engine fault now because i use orig file and i need dpf egr off.
Hi, can you increase the pedal map to my Map?
Fiat Punto 1.3 69CVFiat Punto 3 Serie 1.3Mjt 69CV_egroff_mappa.mod.zip
prima di tutto.il tuo tuner e un ladro...la tua rimapatura non e il tuo originale file rimappatto...adesso tu usi un file dalla una collezione di tuning file vendutti per stronzi sull e-bay
first of all,your mod file is not your original file worked...is from other simmilar car from some file colection...shit tuner
inside forum:ask me about...i will tell you all that i know
make me working for you...i will give you my paypal account
outside forum:
chiptuning,egr,dpf,add blue,dtc,Eu clones
Here,
Good quality tuning for your bmw
Sedat Garip
Chiptuning Remapping, file service, stage 1 & 2 dyno tested.
Diesel + petrol All cars
Manual Adblue dpf egr Opf tested working solutions
Belgium
With Kind Regards,
Don't forget hit thank button if i helped.
ashm431313 (18th June, 2018)
c4rmine (17th June, 2018)
Vw caddy 1.9 TDI 77kw BLS
Hi need dtc off p0431 vag16725 thanks.
DK is the best !!
Department of factory errors.
here you file do not forged thx rep
can't download the file order files can strange
DK is the best !!
please read PM
