digger75 (13th March, 2016)
hi mate
you have same all ecu hw sw number patcher software
all use the same software
program is executed
Press PATCH
Select the file you want modding
When the patch is out okay alert
it only took a few seconds
It's that simple
BAK extension, file the original
If you have selected a file has been tuning
Good day to everyone
I hope you could help
good years
hi mysamed
i know how to do to get the mod file
but,as i trust on you,i will flash your file in the ecu without check it
that's all
problem with files that have not tried all of them
For the first time a file is not in
would not be any problem
I did every day applications
Free,free,free....Be careful with forums files....
Blow turbo, injectors broken, clutch crash, broken pistons, engine completely down, Etc.....
Good tuned files cost under price of motor parts...
If you want very good work, also pay for dyno tune....
Remember that when you was in side of the road in the grass (or SAFETY BARRIER !) with the rain....
Good tune at all !
Ed
Byteshooter Master all protocols, Alientech K-Tag Master , Piasini Master, Bdm with alu positioning frame, MPPS V15, Alientech powergate II M.
EVC WinOls, ECM Titanium, Volta.
RossTech VCDS 11.11, Actia Multidiag pocket, Alientech Stekio.
Learn, tuning, same war...
Hi people, can you give me some help with finishing this file.
It is Alfa Romeo 156 2.0 ts 16v 114kw M.1.5.5 ecu
Thanks in advance
can you mod my ori file?
It's bmw 320d 163HP Automatic
Thanks!
please need chip tuning fuel economy, less for power
if anyone can let me help
hello,
can anyone help me to tune this file its a little bit complicate for me!!
regards.
Audi A3 2.0 tdi from 2005
0281011905
1037375970
WORK WITH KWP 2000+, GALLETO 1260, BDM 100, FLASTEC CLONE WITH MAGPRO2, VAGCOM, FIAT ECUSCAN,UPA USB, MAXIDIAG, TOP 2049, PROG EXPRESS, AND MORE....
Hello!
I m a new for chiptuning.
I have the byteshooter mini and galletto 1260.
I have reading some ecus and I take the original files...If I d like to write in the ecu the mod file what I must change in the mod file to start the engine and how I can do this change!!
Thank a lot!!!
