Page 88 of 1261 FirstFirst ... 38788384858687888990919293981381885881088 ... LastLast
Results 1,306 to 1,320 of 18904
  1. #1306
    here yo go. different sw but same ECU works anyway.
    Audi TTS 2.0TFSI 272HP 8J0907115Q 0261S02581 393740.rar
  2. The Following 2 Users Say Thank You to ominimicu For This Useful Post:
    digger75 (14th March, 2016), mines (24th May, 2020)
  3. #1307
    Germany
    thanks but i need ori exactly from my request to compare a modded file :-(
    rgds
    work with :
    EVC Winols 3.32 , Swiftec Full V1.9.1.6 , ECM Titanium V1.73 , New Fgtech Galletto 4 Eu V54 and V54 Mini High End , Mpps V18 , Byteshooter Truck V4.0 , Vag K+Can , Vag Tacho V5.0 , Alientech K-Tag V2.12 , MRM Rns Manager 6.55 , VCDS AI 14.10.1 , VAGDashcan 5.17 , VCP Can Pro , Magic Motorsport Magpro 2 , X17 , Password Plugin !
  4. The Following User Says Thank You to tobygolf66 For This Useful Post:
  5. #1308
    Maps inside should be the same with the same values. post your ori
  6. The Following User Says Thank You to ominimicu For This Useful Post:
  7. #1309
    Germany
    its not the same, i have compared the file from you with my mod.
    work with :
  8. The Following User Says Thank You to tobygolf66 For This Useful Post:
  9. #1310
    Jan 2013
    can some one make this megane 1.5 dci quicker, thanks.stefs megane.rar
  10. The Following User Says Thank You to galsy For This Useful Post:
  11. #1311
    Quote Originally Posted by tobygolf66 View Post
    search Ori Flash from 2.0 TFSI MED9 396750 0261S02331 8J0907115Q
    You wil never find it because 0261S02331 8J0907115Q does not exist.
    0261S02331 is 1K0907115J Golf BWA engine
    8J0907115Q must have 0261S02581 Bosch # ONLY!!
    Maybe numbers were specially changed by tuning to hide base original source.
    Post file you have read from ECU. Maybe we can determinate which file is ori for it.
  12. The Following User Says Thank You to veloseeped For This Useful Post:
  13. #1312
    Default Peugeot 206 16v 80kw ME7.4
    Hi, can anybody help me remap my car? David
    Peugeot 206 1.6i 16V 80kW ME7.4
    Peugeot 206 1.6i 0261206942 353507.zip
  14. The Following User Says Thank You to parik For This Useful Post:
  15. #1313
    Germany
    ok,maybe.here is the file
    rgdsERRORv1_3fehler_canoff.zip
    Quote Originally Posted by veloseeped View Post
    work with :
  16. The Following User Says Thank You to tobygolf66 For This Useful Post:
  17. #1314
    Now it's all clear.
    Some clown-"tuner" wrote 8J0907115Q 0020 software over incompatible hardware/software 1K0907115J ECU using OBD-mode.
    Stupid idea - tune 200PS engine writing 270PS dump inside - don't think about this engines have serious differences in hardware.
    Now inside is hybrid dump - first 0...7FFF address area stay unchanged from 0261S02331 ECU and second tail are rewritten as for 0261S02581 8J0907115Q 0020 396750 ECU
    Of cause this "hybryd" ECU will not work normally...
  18. The Following User Says Thank You to veloseeped For This Useful Post:
  19. #1315
    Jun 2012
    La Coru?a - Spain
    Default Please tune this siemens ppd. VAG 2.0TDI 140PS.
    Hi.
    Please need more power for this one.
    Thanks.
  20. The Following User Says Thank You to camil For This Useful Post:
  21. #1316
    Germany
    ok now i know why car is not running with full Power :-(
    but why do someone this ?? is the file tuned to 320hp ??
    on the engine is changed, turbo k04,Audi TTS hd pump, injectors TTS,Maf TTS.
    rgds
    rgds
    Now it's all clear.
    work with :
  22. The Following User Says Thank You to tobygolf66 For This Useful Post:
  23. #1317
    Hi.
    Please need more more power for this one
    BMW e90 320d 2006
    Thanks!
  24. The Following User Says Thank You to cheester For This Useful Post:
  25. #1318
    TTS 115Q part of dump isn't stock. Easy to see somebody try to tune it.
    But make hybrid dump was initially bad idea.
    You must take stock dump for your car as base and than tune it according new components installed.
  26. The Following User Says Thank You to veloseeped For This Useful Post:
  27. #1319
    GB
    hy to all need file for 0281010253 original file please help to restore an ecu thancks in advance
  28. The Following User Says Thank You to iustin73 For This Useful Post:
  29. #1320
    Jun 2009
    Hi, can I have tuned file for T4 Multivan 2,5 TDI 102 HP. ECU 0 281 010 458.
    Here is original file.
    Thanks.
  30. The Following User Says Thank You to bochen For This Useful Post:
