Page 22 of 30 FirstFirst ... 121718192021222324252627 ... LastLast
Results 316 to 330 of 441
  1. #316
    Oct 2008
    On Earth
    Sorry with dumps I cannot help you. As I told you I don't share dumps.
    "To help you with something" - what does it mean.
    Good luck
  2. #317
    Feb 2016
    ok.
    Can you tell me what programmer would be able to copy dump?
  3. #318
    Always atmega is blocked to read flash and eeprom.
  4. #319
    Feb 2016
    There must be a solution
  5. #320
    Mar 2017
    Quote Originally Posted by betonel View Post
    Tested VCDS 11.11.0 dump
    hex files are for pony prog, bin files for upa.
    Here you can find dump (Atmega flash+eeprom)
    Use VCDS 11.11.0 loader if you have a RL interface. Remove rar extension from filepart of VCDS software.
    When programming, keep in mind correct order:
    1. CHIP ERASE
    2. FLASH
    3. EPROM
    4. FUSE BITS
    5. LOCK BITS
    VCDS v11.11 ATMEGA162 Fuses & Lock bits
    # LOCK: 0b11111100
    # bit 7 = -
    # bit 6 = -
    # bit 5 = BLB12 (1)
    # bit 4 = BLB11 (1)
    # bit 3 = BLB02 (1)
    # bit 2 = BLB01 (1)
    # bit 1 = LB2 (0)
    # bit 0 = LB1 (0)
    # EFUSE: 0b11111001
    # bit 7 = -
    # bit 6 = -
    # bit 5 = -
    # bit 4 = M161C (1)
    # bit 3 = BODLEVEL2 (1)
    # bit 2 = BODLEVEL1 (0)
    # bit 1 = BODLEVEL0 (0)
    # bit 0 = -
    # LFUSE: 0b11111101
    # bit 7 = CKDIV8 (1)
    # bit 6 = CKOUT (1)
    # bit 5..4 = SUT1:0 (11)
    # bit 3..0 = CKSEL3:0 (1101)
    # HFUSE: 0b11011100
    # bit 7 = OCDEN (1)
    # bit 6 = JTAGEN (1)
    # bit 5 = SPIEN (0)
    # bit 4 = WDTON (1)
    # bit 3 = EESAVE (1)
    # bit 2 = BOOTSZ1 (1)
    # bit 1 = BOOTSZ0 (0)
    # bit 0 = BOOTRST (0)
    Forum VCDS-Release-11.11.0-Installer can not extract, who can use the VCDS-Release-11.11.0-Installer EMAIL:431894@qq.com. Thank you
  6. #321
    May 2017
    Hi all
    I have a question. I have now Interface VCDS 11.11 PL/EN (language). It is on hardware which i show on images in link below:
    https://goo.gl/photos/Lnb21G1m4pZvpCXu5
    Is any chance to change this FW and done this interface to work with VCDS 17.1.3 ? Please help me step by step how i can do it. Sorry for my english
  7. #322
    Oct 2008
    On Earth
    Yes you can
    All the tutorials in the forum.
    I am not an active member anymore. So I have no time to creat a tutorial.
    But you will haven't Polish vcds active anymore.
    Good luck
    Matty
  8. #323
    May 2017
    Please give me link to tutorials... i try find but i can not.
    Please
  9. #324
    in first 10 pages you will find.
  10. #325
    Jan 2011
    REUNION ISLAND
    GOOD POST THANKS
  11. #326
    Mar 2016
    Hi I have az oringinal Ross-Tech desing interface it's China -Clone...
    My license is gone away by Internet....
    Can you help me to bring it alive...?
    The interface is visible, i can test it, but th license is DEMO...
    Can you share me dump files?
    The current FW is 1.96
    17.1.3
    ATmega 162
    FT232RQ
    thanks..
  12. #327
    May 2017
    Hi all
    I think about buying from china clone vcds. What do you think about it:
    http://s.aliexpress.com/yMRJNvAV
    It is probably new version... please help mr
  13. #328
    Jul 2017
    Hi everyone. I have vag 12.12.0 chinese clone. worked fine for a while, and in one day when i tried to do a auto-scan, at some point showed me the message 'this function requires a licensed interface'. i checked 'about' and it shows unregistered. i used the software that came with the cable, which prompts to close internet con, and changes the date automatically. it's like a demo. i still can do some things whith it. any chance to make it fully working again? thanks in advance. sorry for my poor english .
  14. #329
    Open it and check if there is atmega162 or NEC processor.
  15. #330
    Jul 2017
    it has a warranty seal. and i didn't rip it of yet.any chance to find out the type of processor without open it ? i read the entire thread, and i know the nec's one are pretty bad. if it's a atmega, i still need to use a special tool to reflash?
